I had a major hardware failure yesterday and I’m trying to rebuild, but for some reason I’m unable to get the supervised version of Home Assistant running on Ubuntu. I’ve done this many times before without issue, but for some reason this time I’m having a terrible time getting it to work. I’m following the steps outlined here to the letter > Install Home Assistant (Supervised) on Debian - Matheson Steplock
The problem seems to be when the supervisor starts up and attempts to grab the other containers.
Here are the errors I’m seeing in the supervisor log. ANY help would be GREATLY appreciated.
21-11-10 16:34:52 WARNING (MainThread) [supervisor.plugins.dns] Error on install CoreDNS plugin. Retry in 30sec 21-11-10 16:35:22 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-dns with tag 2021.06.0. 21-11-10 16:35:23 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-dns:2021.06.0: 500 Server Error for **http+docker://localhost/v1.41/images/ghcr.io/home-assistant/amd64-hassio-dns:2021.06.0/json** : Internal Server Error ("layer does not exist") 21-11-10
16:35:23 WARNING (MainThread) [supervisor.plugins.dns] Error on install CoreDNS plugin. Retry in 30sec 21-11-10 16:35:53 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-dns with tag 2021.06.0. 21-11-10 16:35:56 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-dns:2021.06.0: 500 Server Error for **http+docker://localhost/v1.41/images/ghcr.io/home-assistant/amd64-hassio-dns:2021.06.0/json** : Internal Server Error ("layer does not exist")`
