Thank you for this information.
I’m new to both Linux and HA. I just got an RP4 and I would like to install HA Supervised.
I am on this environment:
Linux raspberrypi 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
However, I’ve been having the same problem for three days now:
Depending on the os-agent package installed, I get one of the following errors:
Which happens, I think when I install an os-agent package other than aarch64. Or :
The following packages have unmet dependencies:
homeassistant-supervised : PreDepends: os-agent but it is not installable
E: Unable to correct problems, you have held broken packages.
with the aarch64 package.
However, in both cases, the package installation seems to have been successful, since the command:
gdbus introspect --system --dest io.hass.os --object-path /io/hass/os
does not return any error. So I understand that the os-agent is installed.
I reproduced the tutorial steps on several debian versions, with the same result, with the RP4 connected to wifi and ethernet. I’m completely stumped. Your help will be most welcome
Thanks a lot!
