I’m on a vacation, and I was checking remotely how my HA was doing, but today the supervisor and the addons frontend pages do not load and it show me this error:
(The default pages work just fine)
These are the logs from the settings page (starting from the last check I made):
2020-08-15 03:25:29 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 159, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 61, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.8/socket.py", line 918, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 670, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 381, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 978, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 309, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 171, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x706aa5b0>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 726, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 439, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='setup.icloud.com', port=443): Max retries exceeded with url: /setup/ws/1/login?clientBuildNumber=17DHotfix5&clientMasteringNumber=17DHotfix5&ckjsBuildVersion=17DProjectDev77&ckjsVersion=2.0.5&clientId=1DA14490-DCD5-11EA-8CFF-B827EB92F6CA&dsid=12095457451 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x706aa5b0>: Failed to establish a new connection: [Errno -3] Try again'))
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/icloud/account.py", line 284, in keep_alive
self.api.authenticate()
File "/usr/local/lib/python3.8/site-packages/pyicloud/base.py", line 235, in authenticate
req = self.session.post(
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 578, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.8/site-packages/pyicloud/base.py", line 74, in request
response = super(PyiCloudSession, self).request(method, url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='setup.icloud.com', port=443): Max retries exceeded with url: /setup/ws/1/login?clientBuildNumber=17DHotfix5&clientMasteringNumber=17DHotfix5&ckjsBuildVersion=17DProjectDev77&ckjsVersion=2.0.5&clientId=1DA14490-DCD5-11EA-8CFF-B827EB92F6CA&dsid=12095457451 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x706aa5b0>: Failed to establish a new connection: [Errno -3] Try again'))
2020-08-15 19:30:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-15 19:30:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-15 20:25:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-15 20:25:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-15 21:20:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-15 21:20:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-15 21:39:31 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-08-15 22:15:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-15 22:15:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-15 23:10:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-15 23:10:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 00:05:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 00:05:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 01:00:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 01:00:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 01:55:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 01:55:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 02:50:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:50:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 02:52:40 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:52:50 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:52:58 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:53:08 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:53:17 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:53:21 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:53:23 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:55:19 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:55:41 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:55:57 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/restart request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:56:37 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:57:07 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:57:11 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:57:44 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:58:44 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:58:55 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:58:56 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:59:10 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 02:59:26 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/restart request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 03:05:42 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 03:30:34 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 03:45:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 03:45:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 04:40:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 04:40:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 05:35:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 05:35:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 06:30:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 06:30:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 07:25:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 07:25:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 08:20:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 08:20:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 09:15:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 09:15:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 10:10:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 10:10:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 10:51:42 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 11:05:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 11:05:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 12:00:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 12:00:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 12:55:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 12:55:50 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version:
2020-08-16 13:11:31 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.4
2020-08-16 13:11:33 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.4
2020-08-16 13:11:46 WARNING (MainThread) [homeassistant.components.switch] Updating adguard switch took longer than the scheduled update interval 0:00:10
2020-08-16 13:12:09 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.4
2020-08-16 13:12:29 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 13:12:39 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
2020-08-16 13:12:46 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
I tried restarting HA from the Server Controls page, but the buttons are unresponsive (and an error is recorded in the logs).
I’m running 0.114.0, I noticed this problem because I saw the updater entity triggered and I was going to update HA from the supervisor page, but it didn’t load (I had this problem where the cpu usage was slowly rising after every boot, from 1% to about 35% on my rpi2 in about 2 days and I thought another update would fix it).
I just wanted to know if I can do something remotely to fix it, as I will be back home in about a week and I don’t like leaving it like this.
(I make automatic snapshots with the Google Drive Backup addon twice a week for good measure)
