Home assistant supervisor complaining about "Ring"
Home assistant supervisor is complaining about a “Ring” plugin, however, I don’t have that plugin at all (never had) , what going on here ?
2024-04-17 17:04:33.718 WARNING (SyncWorker_2) [supervisor.store.data] Can't read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {'pluginAlias': 'Ring', 'pluginType': 'platform', 'singular': True, 'customUi': True, 'customUiPath': './lib/homebridge-ui', 'customUiDevServer': 'http://localhost:3000/api/plugins/settings-ui/homebridge-ring', 'headerDisplay': 'See [the wiki](https://github.com/dgreif/ring/wiki/Refresh-Tokens) for details on generating a refresh token', 'accountLinkingHeader': 'Please supply your Ring credentials.  These will be used to contact the Ring servers and generate a unique access token for your acc...
I have exactly the same entry in my log and just like you, i never installed any ring or homebridge add on. I hope someone can explain.
I believe it’s something that the Scrypted Add-On uses, so HA checks it.
I do use Scrypted, but no Ring products. I wasn’t able to find a specific Ring plug-in, though, which is disappointing.
