Home Assistant Supervisor does not load up after powercut
i noticed that when i moved to an ssd for boot, HA OS does not boot up properly ( with addon’s ) and gives the below errors. a reboot or two usually fix this.
Unable to set up dependencies of raspberry_pi. Setup failed for dependencies: hassio 09:54:16 – (ERROR) setup.py Error during setup of component hassio 09:54:02 – (ERROR) components/hassio/handler.py Can't read panel info: System is not ready with state: setup 09:54:02 – (ERROR) hassio Can't read Supervisor data: System is not ready with state: setup 09:54:01 – (WARNING) hassio Not connected with the supervisor / system too busy! 09:54:00 – (WARNING) hassio
Also gets errors for raspberry_pi
Setup failed for raspberry_pi: (DependencyError(...), 'Could not setup dependencies: hassio') 09:54:16 – (ERROR) setup.py Unable to set up dependencies of raspberry_pi. Setup failed for dependencies: hassio 09:54:16 – (ERROR) setup.py
Please help
