Ive been running HA for a year or two with no issues, exoloring and adding to my system. Initially on a Docker image on a synology, then for the last year as a virtual machine within the synology. Works well.
However, I’m having difficulty now for the last few days with an update to Supervisor that just wont take. Logs look to point to a DNS lookup fail on a git hub site; however I can browse to there on home network. I’ve pihole and some geo blocks in place on the unifi SE but again i can get to the site fine on other machines. Can anyone tell me what I’m doing wrong?
Log reads
Log Details (ERROR)
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:240
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:54:30 (1 occurrences)
Last logged: 12:54:30
[140317449765696] Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.02.0: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.02.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 258, in async_install
await async_update_supervisor(self.hass)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 55, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.02.0: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.02.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 240, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2279, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2316, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 892, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 962, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 161, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 465, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 260, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.02.0: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.02.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
Log details (ERROR)
Source: components/websocket_api/commands.py:238
First occurred: 12:03:18 AM (1 occurrences)
Last logged: 12:03:18 AM
[281473141923776] Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.02.0: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.02.0&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: TLS handshake timeout")
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 53, in _wrapper
homeassistant.components.hassio.handler.HassioAPIError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.02.0: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.02.0&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: TLS handshake timeout")
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 238, in handle_call_service
File "/usr/src/homeassistant/homeassistant/core.py", line 2149, in async_call
File "/usr/src/homeassistant/homeassistant/core.py", line 2186, in _execute_service
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 272, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 882, in entity_service_call
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 952, in _handle_entity_call
result = await task
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.02.0: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.02.0&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: TLS handshake timeout")
Ok for the next poor soul that lands on this post, this means something is wrong with your network. In my case, my ethernet cable got crushed in a door and was dropping packets. It could be DNS, could be your router needs a reboot… But there’s a problem somewhere.
