I’m running Home Assistant Supervised on Debian on Docker.
I’m using Intel NUC
Normally the rebooting process was taking about 10-20s, but now takes about 10min.
I’ve tried to purge the DB and see if that was the problem but without success.
Here are some Supervisor logs:
21-04-21 15:01:34 INFO (SyncWorker_4) [supervisor.docker.interface] Restarting homeassistant/qemux86-64-homeassistant
21-04-21 15:01:34 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:1000 is not str
21-04-21 15:01:34 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
21-04-21 15:02:41 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-04-21 15:02:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-04-21 15:02:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-04-21 15:02:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-04-21 15:02:41 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-04-21 15:02:41 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-04-21 15:02:41 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-04-21 15:05:14 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-04-21 15:05:16 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-04-21 15:05:16 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-04-21 15:10:30 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-04-21 15:10:31 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
I also got this error from the second reboot:
2021-04-21 17:14:15 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /homeassistant/restart request
What should I try next?
