Home Assistant + Tasmota (Wemos mini R1) + Battery meter KG140F
Hi, i have gotten a d1 mini reading the data from the shunt, but when i add the lines:
mqtt:
  • name: D1_mini_1
    topic: tele/D1_mini_1/RESULT
To my config yaml file, i get this error when checking the config yaml file before i boot: (the topic name in my tasmota config is D1_mini_1). Do i need a ‘full topic’?
Invalid config for [mqtt]: expected dictionary for dictionary value @ data[‘mqtt’]. Got [OrderedDict([(‘name’, ‘D1_mini_1’), (‘topic’, ‘tele/D1_mini_1/RESULT’)])]. (See /config/configuration.yaml, line 198).
Any ideas?
For example, i have the lines in tasmota console:
18:10:31.823 MQT: tele/D1_mini_1/RESULT = {“SerialReceived”:":R50=1,\n:r50=1,87,2669,200,268391,98603,387360,0,129,0,99,0,8420,1000,\r\n:R51=1,\n:r51=1,143,0,0,0,0,0,100,0,0,2800,100,100,100,0,1,1,\r\n"}
Mine is done differently. Try this.
template:
  - trigger:
      - platform: mqtt
      - name: Freezer Battery Temperature
        unit_of_measurement: "°C"
        state: "{{ (trigger.payload.split(',')[9] | float-100) }}"
Thanks, trying how you say, unfortunately nothing shows up, and i now get this in the logs:
Logger: homeassistant.config
Source: config.py:982
First occurred: 8:21:48 PM (3 occurrences)
Last logged: 8:23:50 PM
Invalid config for [template]: [trigger] is an invalid option for [template]. Check: template->sensor->3->trigger. (See /config/configuration.yaml, line 183).
Invalid config for [template]: [trigger] is an invalid option for [template]. Check: template->sensor->3->trigger. (See /config/configuration.yaml, line 180).
Any ideas whay? Thanks again :+1::+1:
Post your yaml config. I am not an expert but let me see if I can help
Hi, thanks for offering your time :blush: (scroll to the bottom, the rest of the yaml it for my inverter, that all works fine…)
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.30.33.0/24
modbus:
  - name: epever
    type: rtuovertcp
    host: 192.168.0.188
    port: 8088
    delay: 5
    timeout: 10
    close_comm_on_error: false
    retry_on_empty: true
    retries: 20
    sensors:
      # Utility
      - name: "Grid Voltage"
        unit_of_measurement: V
        slave: 10
        address: 0x3500
        input_type: input
        scale: 0.01
        precision: 2
      - name: "Grid Current"
        unit_of_measurement: A
        slave: 10
        address: 0x3501
        input_type: input
        scale: 0.01
        precision: 2
      - name: "Grid State"
        # 0:Normal, 1:Low input; 2:High input, 3: No connected
        slave: 10
        address: 0x3511
        input_type: input
      - name: "Grid Total"
        unit_of_measurement: kWh
        slave: 10
        address: 0x350F
        input_type: input
        scale: 0.01
        precision: 2
        data_type: int32
        swap: word
        count: 2
      # PV Array
      - name: "PV Voltage"
        slave: 10
        address: 0x3549
        input_type: input
        scale: 0.01
        precision: 2
      - name: "PV Current"
        slave: 10
        address: 0x354A
        input_type: input
        scale: 0.01
        precision: 2
      - name: "PV Power"
        unit_of_measurement: W
        slave: 10
        address: 0x354B
        input_type: input
        scale: 0.01
        precision: 2
        data_type: int32
        swap: word
        count: 2
      - name: "PV Total"
        slave: 10
        address: 0x3557
        input_type: input
        scale: 0.01
        precision: 2
        data_type: int32
        swap: word
        count: 2
      # Load
      - name: "Load Voltage"
        slave: 10
        address: 0x3521
        input_type: input
        scale: 0.01
        precision: 2
      - name: "Load Current"
        slave: 10
        address: 0x3522
        input_type: input
        scale: 0.01
        precision: 2
      - name: "Load Total"
        slave: 10
        address: 0x3530
        input_type: input
        scale: 0.01
        precision: 2
        data_type: int32
        swap: word
        count: 2
      # Battery
      - name: "Battery Voltage"
        slave: 10
        address: 0x3580
        input_type: input
        scale: 0.01
        precision: 2
      - name: "Battery Current"
        slave: 10
        address: 0x3581
        input_type: input
        scale: 0.01
        precision: 2
      - name: "Battery Capacity"
        unit_of_measurement: "%"
        slave: 10
        address: 0x3586
        input_type: input
        scale: 1
      - name: "Battery Temp"
        #ElectricChrgBatteryTemp
        slave: 10
        address: 0x3512
        input_type: input
        scale: 0.01
      - name: "Battery State"
        # 0:Normal, 1:Overvoltage, 2:Undervoltage, 3:Undervoltage Disconnect, 4:Fault
        slave: 10
        address: 0x3589
        input_type: input
      - name: "Charging Mode"
        # 1:Solar Priority, 2:Utility & Solar, 3:Solar
        slave: 10
        address: 0x9607
        input_type: holding
      - name: "Inverter Mode"
        # 0:Inverter priority, 1:Utility Priority
        slave: 10
        address: 0x9608
        input_type: holding
      - name: "Inverter Temp"
        #LoadHeatSink2Temp
        slave: 10
        address: 0x3533
        input_type: input
        scale: 0.01
template:
    - name: "Grid Power"
      device_class: power
      state: "{{((states('sensor.grid_current')| float(0) * states('sensor.grid_voltage')| float(0))) | round(2) }}"
    - name: "Power into batt"
      state: "{{ states('sensor.grid_power') | float + states('sensor.pv_power') | float }}"
      device_class: power
    - name: "House Load"
      device_class: power
      state: "{{((states('sensor.load_current')| float(0) * states('sensor.load_voltage')| float(0))) | round(2) }}"
    - trigger:
       - platform: mqtt
  - platform: integration
    source: sensor.house_load
    unit_prefix: k
    round: 2
Also, when adding - trigger: - platform: mqtt topic: tele/D1_mini_1/RESULT
then sensors grid_power and house_load stop working also… Causing some kind of problem with the template i think?
see if this works. I put trigger before the sensor.
template:
  - trigger:
      - platform: mqtt
        device_class: power
        device_class: power
        device_class: power
Thanks very much, if also been having a bit of help on another thread i made, and is working now :+1::+1::+1::+1:
Pasted some more lines from giro above to test, but needs some editing as wrong values for current and capacity
# Loads default set of integrations. Do not remove.
default_config:
frontend:
# Text to speech
tts:
http:
  trusted_proxies:
    - 172.30.33.0/24
modbus:
  - name: epever
    type: rtuovertcp
    host: 192.168.0.188
    port: 8088
    delay: 5
    timeout: 10
    retries: 20
    sensors:
      # Utility
        slave: 10
        address: 0x3500
        input_type: input
        scale: 0.01
        precision: 2
        slave: 10
        address: 0x3501
        input_type: input
        scale: 0.01
        precision: 2
        slave: 10
        address: 0x3511
        input_type: input
        slave: 10
        address: 0x350F
        input_type: input
        scale: 0.01
        precision: 2
        data_type: int32
        swap: word
        count: 2
      # PV Array
        slave: 10
        address: 0x3549
        input_type: input
        scale: 0.01
        precision: 2
        slave: 10
        address: 0x354A
        input_type: input
        scale: 0.01
        precision: 2
      - name: "PV Power"
        slave: 10
        address: 0x354B
        input_type: input
        scale: 0.01
        precision: 2
        data_type: int32
        swap: word
        count: 2
      - name: "PV Total"
        slave: 10
        address: 0x3557
        input_type: input
        scale: 0.01
        precision: 2
        data_type: int32
        swap: word
        count: 2
      # Load
        slave: 10
        address: 0x3521
        input_type: input
        scale: 0.01
        precision: 2
        slave: 10
        address: 0x3522
        input_type: input
        scale: 0.01
        precision: 2
        slave: 10
        address: 0x3530
        input_type: input
        scale: 0.01
        precision: 2
        data_type: int32
        swap: word
        count: 2
      # Battery
        slave: 10
        address: 0x3580
        input_type: input
        scale: 0.01
        precision: 2
        slave: 10
        address: 0x3581
        input_type: input
        scale: 0.01
        precision: 2
        slave: 10
        address: 0x3586
        input_type: input
        scale: 1
        slave: 10
        address: 0x3512
        input_type: input
        scale: 0.01
        slave: 10
        address: 0x3589
        input_type: input
        slave: 10
        address: 0x9607
        input_type: holding
        slave: 10
        address: 0x9608
        input_type: holding
        #LoadHeatSink2Temp
        slave: 10
        address: 0x3533
        input_type: input
        scale: 0.01
template:
- sensor:
      device_class: power
      device_class: power
      device_class: power
- trigger:
  - platform: mqtt
    - name: Temperatura
    - name: Tensione
      unit_of_measurement: "V"
      state: "{{ (trigger.payload.split(',')[3] | float/100) }}"
    - name: Corrent
      unit_of_measurement: "A"
      state: "{{ (trigger.payload.split(',')[4] | float/100) }}"
    - name: Potenza
      unit_of_measurement: "W"
      state: "{{ (trigger.payload.split(',')[6] | float/100) }}"
    - name: Capacità
      state: "{{ (trigger.payload.split(',')[5] | float/11000*100) }}"
    - name: Consumato
      unit_of_measurement: "kWh"
      state: "{{ (trigger.payload.split(',')[6] | float/10000) }}"
    unit_prefix: k
    round: 2
I used the info provided by OP and this thread to link my Juntek 100A shunt to Home assistant.
I appreciate this, it feels good to have this info visible without having to reach for my phone or walk to the display.
I was able to link the state of charge and I’ll paste my code in case others can use it.
My code has all the sections of r50 because I wanted to monitor the values to see the info it carried
This code goes in the configuration.yaml (putting this down as it stumped me when I found the thread as a newb)
One thing I’m stumped on as this is my first HA project, is the value for the AMPS being used is sent as a positive number even when the amps are being drawn.
I found the value that corresponds to the negative and positive switch.
It’s down the string at section [12], it returns a 0 if the amps are negative and it returns a 1 if the amps are positive.
Can anyone suggest a code that will watch the section at [12] and if it is 1 do nothing but if it is 0 it would take the value and subtract the value x 2.
var pos/neg
var amps
if [12] = 1
do nothing
if [12] = 0
pos/neg = amps - (amps + amps)
or a conversion trick to reverse polarity of an sensor value.
I’m new to HA code
template:
  - trigger:
      - platform: mqtt
      - name: SOCX
        state: "{{ (trigger.payload.split(',')[2] | float/11000*100) }}"
      - name: Voltage
      - name: Current
      - name: Amp Hours Remaining
        unit_of_measurement: "AH"
        state: "{{ (trigger.payload.split(',')[5] | float/1000) }}"
      - name: Battery Remaining
        unique_id: 0000420000-1
        state: "{{ (trigger.payload.split(',')[5] | float/10/400) }}"
      - name: Total Power Used
        state: "{{ (trigger.payload.split(',')[6] | float/1000) }}"
      - name: Elec. Consumption
        unit_of_measurement: "kW-h"
        state: "{{ (trigger.payload.split(',')[7] | float/100000) }}"
      - name: Total kW-h
        state: "{{ (trigger.payload.split(',')[8] | float/10000) }}"
      - name: Temperature
      - name: VoltageXX
        state: "{{ (trigger.payload.split(',')[10] | float/100) }}"
      - name: CurrentXX
        state: "{{ (trigger.payload.split(',')[11] | float/100) }}"
      - name: pos/neg
        state: "{{ (trigger.payload.split(',')[12]) }}"
      - name: Battery Life AH
        state: "{{ (trigger.payload.split(',')[13] | float/10) }}"
      - name: Internal Resistance
        unit_of_measurement: "m-Ohm"
        state: "{{ (trigger.payload.split(',')[14] | float/100) }}"
Hi, my Tasmota consolle doesn’t show 11:27:23.727 MQT: tele/BatteryMonitor/RESULT = same as others. Did I miss something?
Hope you did not miss this
Rule1 on System#Boot do RuleTimer1 10 endon on Rules#Timer=1 do backlog SerialSend :R50=1,2,1,; RuleTimer1 10 endon
Rule1 1
Check also the connection between KG140F and your Wemos mini (or whatever you use)
Hi Giro,
can you please suggest a RS485 converter? Or send some detail (chip name and input and ouput connection) and a picture of your?
I buyed a rs485 to TTL but it doesn’t seem to be correct for this job.
Thank you very much.
Lucio
I’m a noob in home assistant but i want to contribute with this community.
After reading the documentation about the KG140F DC 0-120V 100A and compare it with the information of this thread I got the following information:
The communication channel give me the following:
My shunt has this values:
r50=2,215,2056,200,5408,4592,9437,14353,134,0,0,0,162,30682
Explanation:
position    Description
1           2 represents the communication address;
2           215 represents the checksum;
3           2056 represents the voltage of 20.56V;
4           200 represents current 2.00A;
5           5408 represents the remaining battery capacity is 5.408Ah;
6           4593 means the cumulative capacity is 4.593Ah;
7           9437 represents the watt-hour is 0.09437kw.h;
8           14353 represents the running time of 14353s;
9           134 represents the ambient temperature is 34℃;
10          0 means the function is pending;
11          0 means the output status is ON; (0-ON, 1-OVP, 2-OCP, 3-LVP, 4-NCP, 5-OPP, 6-OTP, 255-OFF)
12          0 represents the direction of current, and the current is forward current; (0-forward, 1-reverse)
13          162 means battery life is 162 minutes;
14          30682 represents the internal resistance of the battery is 306.82mΩ.
Decoding:
                                HA position split
Address(1,2,3,4,5,6,....)               1
Checksum:153,		                    2
Voltage(V)(2056->20.56)                 3
CurrentAmpere(A)(200->2.0)              4
RemainingAh(Ah)(5408->5.408)            5
ElapsedAH(Ah)			                6
AccumulatedChargingCapacity(Kwh)	    7
RunningTimeSeconds,				        8
Temperature(ºC)(134->34ºc->134-100)     9
pending 		                        10
OutputStatus(alarms)                    11
CurrentDirection(0/1)                   12
BatteryLifeMinutes      	            13
ohm(30682->306.82->30682/100)           14
After struggling my head with the sensors, templates and so on, i finished with the following package(yaml file): pck_enrgyconsum_battery_control.yaml
input_number:
  number_ampere_preset:
    icon: mdi:battery-high
    min: 0
    max: 360
    initial: 127.5
    step: 0.1
    mode: box
    unit_of_measurement: Ah
template:
  - trigger:
      - platform: mqtt
        topic: tele/tasmota_03-ESP32-Shunt-PowerBank/RESULT
      - name: KG140F-01-Address
        # unit_of_measurement: ""
        state: "{{ (trigger.payload.split(',')[1] | float) }}"
      - name: KG140F-01-Checksum
        # unit_of_measurement: "V"
        state: "{{ (trigger.payload.split(',')[2] | float) }}"
      - name: KG140F-01-Voltage
      - name: KG140F-01-CurrentAmpere
        unit_of_measurement: "Ah"
      - name: KG140F-01-RemainingAh
      - name: KG140F-01-ElapsedAH
      - name: KG140F-01-AccumChrgCapacity
        unit_of_measurement: "Kwh"
      - name: KG140F-01-RunningTimeSeconds
        unit_of_measurement: "s"
        state: "{{ (trigger.payload.split(',')[8] | float) }}"
      - name: KG140F-01-RunningTimeHours
        unit_of_measurement: "h"
        state: "{{ (trigger.payload.split(',')[8] | float/60/60) }}"
      - name: KG140F-01-Temperature
        unit_of_measurement: "ºC"
      - name: KG140F-01-Pending
        state: "{{ (trigger.payload.split(',')[10] | float) }}"
      - name: KG140F-01-OutputStatus
        state: "{{ (trigger.payload.split(',')[11] | float) }}"
      - name: KG140F-01-CurrentDirection
        state: "{{ (trigger.payload.split(',')[12] | float) }}"
      - name: KG140F-01-BatteryLifeMinutes
        unit_of_measurement: "min"
        state: "{{ (trigger.payload.split(',')[13] | float) }}"
      - name: KG140F-01-BatteryLifeHours
        state: "{{ (trigger.payload.split(',')[13] | float/60) }}"
      - name: KG140F-01-Ohm
        unit_of_measurement: "mΩ"
# Calculate current power
    sensors:
      kg140f_01_currentpower:
        value_template: >
            {% set t = states('sensor.kg140f_01_currentdirection') | float(0) %}
            {% if t == 0 %}
              {{ '%0.1f' | format ( -1 |float *
                                      states('sensor.kg140f_01_voltage') | float *
                                      states('sensor.kg140f_01_currentampere') | float
            {% elif t == 1 %}
              {{ '%0.1f' | format
            {% else %}
              {{ '%0.1f' | format
            {% endif %}
        unit_of_measurement: 'W'
        friendly_name: KG140F-01 Current Power
      kg140f_01_ampereconsumption:
        value_template: >
            {% if t == 0 %}
              {{ '%0.1f' | format ( -1 |float * states('sensor.kg140f_01_currentampere') | float ) }}
            {% elif t == 1 %}
              {{states('sensor.kg140f_01_currentampere')|float }}
            {% else %}
            {% endif %}
        unit_of_measurement: 'Ah'
        friendly_name: KG140F-01 Ampere Consumption
      kg140f_01_battery_level:
        value_template: >
          {{ '%0.1f' | format
                          (states('sensor.kg140f_01_remainingah') | float * 100 ) /
                          states('input_number.number_ampere_preset') | float
        unit_of_measurement: '%'
        friendly_name: KG140F-01 Battery Level
The only thing that is not working for me, is the tasmota rule, despite whatever i put in the rule, the transmission to the HA is every second… I bought some D1 mini, just for check if the problem is the ESP32 or not.
Rule1 1
So the dashboard is:
When the shunt detect the negative current:
When the shunt detect the positive current(charging):
Thanks a lot to all of you for your knowledge
Luis.
Thank you all for this. Seems perfect for RV use also!
Has anyone figured out how to filter only the “:R50=1,2,1” message?
I still have the same issue with the 50 and the 51 messages being received and sent. I note that when I put the display in Settings mode, only 50 is sent. When I take it off to the normal display, the 51 pops back up. I want to filter out all 51 messages so they are not sent via MQTT. I thought the Tasmota rule1 would filter to only 50 message, but it still sends both… Any ideas?
I notice that sometimes both the 50 and 51 messages come together in one line in the console, where others, it comes on its own line…I just want to filter out for 50 messages. I did notice that I had to change the tasmota command to align with my address being 2 vs 1, but I still dont get it. My only way to make it work is to put my display on settings and leave it there. Then all the 51 messages stop sending
As i could not find a way to filter out 51, I switched to esphome and I am fine now. Link below
https://github.com/krasa/esphome-junctek_kgf
