Home Assistant Thermometer Integration
Hi everyone!
I bought a wifi thermometer / hygrometer (brand “Kecheer”), perfectly compatible with Google. I initialized it with Smart Life and everything works perfectly: even Google can integrate without problems and correctly answer questions like “What temperature do I have in the room?” or “What humidity is there in the room?”.
Even Home Assistant recognized the thermometer immediately, through the integration of Smart Life / Tuya. However, it automatically sets to “switch” and not to “sensor”. Consequently, I cannot view the temperature / humidity graph and I cannot even create automations such as "turn off the heating if the temperature marked by the thermometer exceeds 20 °).
Home Assistant recognizes the device, but not correctly. He doesn’t see it as a thermometer but as a smart plug!!! How can I solve in your opinion?
Thank you in advance!
P.S.: You can see the attached files for more infos about my issue…
Amazon link of thermometer: https://www.amazon.it/Kecheer-Termometro-Termoigrometro-temperatura-compatibile/dp/B08RC27J5Z/ref=sr_1_1_sspa?__mk_it_IT=ÅMÅŽÕÑ&crid=1FMYA0ORVKOX5&dchild=1&keywords=kecheer+wifi&qid=1613661511&sprefix=kecheer+wi%2Caps%2C162&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFDSUxVSzhXVEoyS0wmZW5jcnlwdGVkSWQ9QTA4OTgxMTVENDNXVUNKUlk1WDImZW5jcnlwdGVkQWRJZD1BMDQxNzcyNjFWWTNOUEE3QTJDR1Amd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl!
