siobhan
(Siobhan)
July 15, 2023, 8:01am
1
I’m new to HA, so please bare with me.
I recently did an update to the latest version 2023.7.2
I am running a docker version on VirtualBox on macOS.
Now, I can’t get the UI to start on 8123. However, if I look at the Home Assistant Observer on 4357 that works, and it shows
Supervisor: Connected
Supported: Supported
Healthy: Healthy
I did notice that when it booted there was an issue with the time sync. I have looked into that, and the only references I can find are that ipv4 isn’t running, which it clearly is as I can run the Observer.
anyone give me a pointer on where to look and what to do?
Many thanks
siobhan
(Siobhan)
July 15, 2023, 10:04am
2
I’ve also tried using UTM (Which seems much faster) and the time synchronisation is still an issue
siobhan
(Siobhan)
July 15, 2023, 5:27pm
3
so I’ve read that hassio will not start without ntp.
This is definitely an issue with Home Assistant.
Everything else that requires ntp in my home works, and I can ping uk.pool.ntp.org (I’m in the UK)
Any clues, any one?
siobhan
(Siobhan)
July 15, 2023, 6:04pm
4
A bit more info… as I figure out how to do things.
When I type
systemctl status systems-timesyncd.service
it tells me:
home assistant systems-timesyncd[7623]: Timed out waiting for reply from 192.168.4.1:123 (192.168.4.1)
192.168.4.1 is my Eero Pro router.
