Home assistant update osmanager.update blocked from execution, killing memory
Hi guys,
I am getting this message when trying to update:
home assistant update osmanager.update blocked from execution,
It looks like the docked hassio_dns is taking is causing the issue if I kill it then performance get back to normal:
docker stop hassio_dns
it actually takes a long time to load this:
I am running a VM on nixos, and the VM is killing the memory 150% cpu, this is my sys info:
System Information
version core-2023.8.0
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.11.4
os_name Linux
os_version 6.1.34
arch x86_64
timezone America/Los_Angeles
config_dir /config
AccuWeather
error failed to load: unknown
Home Assistant Cloud
logged_in false
can_reach_cert_server failed to load: unreachable
can_reach_cloud_auth failed to load: unreachable
can_reach_cloud failed to load: unreachable
Home Assistant Supervisor
host_os Home Assistant OS 10.3
update_channel stable
supervisor_version supervisor-2023.10.1
agent_version 1.5.1
docker_version 23.0.6
disk_total 30.8 GB
disk_used 7.4 GB
healthy true
supported true
board ova
supervisor_api ok
version_api failed to load: unreachable
installed_addons Terminal & SSH (9.7.1), ESPHome (2022.3.1), Studio Code Server (5.13.0), File editor (5.6.0), Mosquitto broker (6.3.1), TasmoAdmin (0.25.1), Duck DNS (1.15.0), Samba Backup (5.2.0)
Dashboards
dashboards 2
resources 2
views 8
mode storage
Recorder
oldest_recorder_run October 26, 2023 at 8:56 PM
current_recorder_run October 28, 2023 at 8:35 PM
estimated_db_size 256.91 MiB
database_engine sqlite
database_version 3.41.2
## System Information
dev false
hassio true
docker true
user root
virtualenv false
os_name Linux
os_version 6.1.34
arch x86_64
config_dir /config
AccuWeather
logged_in false
agent_version 1.5.1
disk_total 30.8 GB
disk_used 7.4 GB
healthy true
supported true
board ova
supervisor_api ok
Dashboards
dashboards 2
resources 2
views 8
mode storage
Recorder
It happened to me as well… just reload the supervisor or restart the container
