Home Assistant Updates and Restarts Not Working
Hi all,
I’ve had a problem with some time that the software updates (which require a restart) I’m doing on Home Assistant are causing some fairly significant problems. The restarts aren’t working - the end result is that I’m often having to force shutdown the PC and then reboot.
I think it must be a problem with my config of Home Assistant somewhere - but I’m not sure where to start (and I definitely don’t want to do a reinstallation!).
HA is running on Proxmox 7.4.17.
HA Core is on 2024.7.1. I’m on Supervisor 2024.09.1 (OS 13.1 and frontend 20240705.0).
Other than restoring a backup (which I do have but no idea when the issue happened)…is the best way to go through the logs?
And do I start with Errors or Warnings - there are a lot!!!
yes, that is the best way. Do a restart attempt and then look in the most recent part of the log.
Ok - thanks. I’ll try that way…
I’ve got lots of errors in the logs!
It should say why it will not restart.
Hi markgolledge,
Reading log errors, fixing instability, a couple of links here might help you…
The Home Assistant Cookbook - Index.
