"Home Assistant URL" section is missing
Suddenly the “Home Assistant URL” section under Settings > System > Network is missing.
Only the basic configuration of HTTP is defined in the configuration.yaml
HTTP configuration
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.0.101 # Add the IP address of the proxy server
Nor internal_url or external_url parameters are defined.
I think this happened after activating Advance
My user is admin and I have tried enabling and disabling the Adcance mode and using a private browser window (It doesn’t appear in the Android APP either)
I am running the latest HA version
2025.9.0
Any help on this would be appreciated.
Thank you.
After updating to:
2025.9.3
The problem seems to persist, “Home Assistant URL” section is still missing:
Is anyone else having the same problem?
Any help would be appreciated.
Thank you.
Please post a portion of your configuration.yaml silmilar to this
default_config:
homeassistant:
 media_dirs:
    local: www/media
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
template: !include template.yaml
My configuration file is pretty much like the original one.
Please, find attached my configurtion.yaml below:
default_config:
homeassistant:
  internal_url: http://192.168.1.101:8123
# HTTP configuration
http:
  trusted_proxies:
    - 192.168.1.101 # Localhost
# Database configuration
recorder:
  db_url: mysql://homeassistant:[email protected]:3306/ha_db?charset=utf8mb4
  purge_keep_days: 30
# Load frontend themes from the themes folder
frontend:
# Include external configuration files
python_script:
Thank you for your help.
homeassistant:
If I remove that config from my config file and restart HA it doesn’t make any difference.
The “Home Assistant URL” section is still missing.
If I add an “external_url:” to the configuration.yaml:
homeassistant:
  external_url: https://app.xxxx.com
The section appears again in HA but it is not editable.
Did you clear the browser cache after removing those entries?
Yes, I even opened the HA UI in incognito mode:
BUT while doing the tests I “recovered” from this bug by mistake :joy:. Here are the steps I followed in case anyone else is having this issue:
  1. Before removing this config from my configuration.yaml
I had left the HA Network tab open in my browser by mistake. The fields weren’t editable at the moment.
  1. Then, I removed the homeassistant: config block from my configuration.yaml, leaving it like this:
  1. I restarted the HA server. Suddenly, the “Home Assistant URL” inputs became editable again, and I was able to change the settings directly from the UI. Then I clicked the save button:
  1. After restarting HA, the Home Assistant URL section was no longer missing and remained editable. :tada:
I hope these steps help someone else recover from this bug, and maybe also help the developers fix it.
Thanks again @LiQuid_cOOled for your help!
