Home-assistant_v2.db grows, despite setting up InfluxDB
I have set up InfluxDB, and thought that would mean that home-assistant_v2.db would not continue to grow any larger. But it does. Is this normal? Or have i configured something wrong?
I know InfluxDB works, as I have Grafana pulling date from it.
Do you have a purge setup to run quite frequently and re-write the file to shrink it?
I have set influx thus:
#### Database
influxdb:
  host: 192.168.1.4
…and set up purge like this:
# Enable recorder and set days to purge DB
recorder:
  purge_interval: 1
  purge_keep_days: 1
-But i thought the whole reason for setting up an external database was (amongst other things) not to fill the SD-card on my Pi3/Hass.io installation with the native database?
InfluxDB runs in parallel to the recorder DataBase selected and not used by recorder or history.
For the recorder you can use a sql-lite or another DB like MariaDB, etc.
See this link, and specifically the repack option which should shrink the DB backing storage.
Thank you! I did not know it intentionally ran in parallel - now I’m off to learn new things!
Merci Vielma!
