Hi, was just surprised when I checked the size of my last snapshot, around 1Gb. Then I checked the db file Home-assistant_v2.db that was 4354544.0KIB, seems enormous. Any option to clean or optimize it?
The is my recorder set up, I stole it from someone a long time ago. You can customize this to suit your needs.
recorder:
purge_keep_days: 7
include:
domains:
- sensor
- binary_sensor
- switch
- light
- device_tracker
- vacuum
- group
- input_boolean
- cover
- person
- counter
- timer
- climate
exclude:
event_types:
- service_removed
- service_executed
- platform_discovered
- homeassistant_start
- homeassistant_stop
- feedreader
- service_registered
- call_service
- component_loaded
- logbook_entry
- system_log_event
- automation_triggered
- script_started
- timer_out_of_sync
Thanks, will do that. Did you also tried the parameter
repack: true?
Edit: it works well, thanks, size reduced to 436Mb.
