Home-assistant_v2.db size growing, error on manual purge
Dear All,
My Home Assitant DB home-assistant_v2.db is growing and growing although I have this recorder setting:
recorder:
# Delete events and states older than 2 weeks
   purge_keep_days: 14
DB size is over 8 GB already. I think purge is not working since an update a couple of versions ago.
I tried manual purge with the service recorder.purge, an found this in the log:
Jul 14 21:36:37 pi hass[22750]: Traceback (most recent call last):
Jul 14 21:36:37 pi hass[22750]:   File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner
Jul 14 21:36:37 pi hass[22750]:     self.run()
Jul 14 21:36:37 pi hass[22750]:   File "/home/pi/opt/homeassistant/lib/python3.5/site-packages/homeassistant/components/recorder/__init__.py", line 288, in run
Jul 14 21:36:37 pi hass[22750]:     purge.purge_old_data(self, event.keep_days, event.repack)
Jul 14 21:36:37 pi hass[22750]:   File "/home/pi/opt/homeassistant/lib/python3.5/site-packages/homeassistant/components/recorder/purge.py", line 17, in purge_old_data
Jul 14 21:36:37 pi hass[22750]:     purge_before = dt_util.utcnow() - timedelta(days=purge_days)
Jul 14 21:36:37 pi hass[22750]: TypeError: unsupported type for timedelta days component: NoneType
Any help would be appreciated! Is this a bug? Should I change the configuration? How to keep this DB small?
Thanks!
Still haven’t found a solution :frowning: DB size reached 7.7 GB…
Any tips will be appreciated!!!
Did you try repack service of recorder?
Thanks! That solved my problem!
what did you do specifically to solve it? Thanks.
use the services page under the dev tools like on How to manually use recorder purge service
and be patient, because it simply takes time.
