Hello
I’m reading directly from the database home-assistant_v2.db.
I’m a bit puzzled what the absolute time is, used to write to the database.
- in homeassistant (the front end): it’s using the Europe/Brussels time zone (the one I live in
- in hassbian: it seems to be BST (British), so one hour difference with the homeassistant frontend (not really an issue).
If I look at the times in the database home-assistant_v2.db, it seems to be two hours difference. Is it somewhere documented what absolute time the recorder is using? (i.e. is it always two hours difference, does it change with winter/summer time, … )
Thanks!
