Hi all,
I’m using arduino connected to usb to my raspberry (ha core version is installed in raspberry).
Inside configuration.yaml I have this:
firmata:
- serial_port: /dev/ttyUSB0
serial_baud_rate: 57600
sensors:
- name: fumo
pin: A1
pin_mode: ANALOG
differential: 20
- name: batteria
pin: A0
pin_mode: ANALOG
differential: 20
binary_sensors:
- name: rete
pin_mode: PULLUP
pin: 13
now I have to change the pin of arduino… but Home Assitant doesn’t like it…
For example I changed the sensor.fumo from A0 to A1 and sensor.batteria from A1 to A0 but now HA shows:
It changed the names…
I tried to erase the browser chace, remove the config lines from config.yaml, reboot and insert again but the problems remains…
I don’t now how “refresh” the new pin…
