Home Assistant Voice PE in boot loop
Hello.
My Home Assistant Voice PE is in boot loop since 2 days.
The LED ring is white “on” (not blinking) for about 20 seconds, then the Voice PE makes a clicking noise and starts over.
Nothing else.
Of course I disconnected the power and tried again several times, without success.
Here is what the log says:
Logger: aioesphomeapi.connection
Quelle: runner.py:154
Erstmals aufgetreten: 15:46:04 (3 Vorkommnisse)
Zuletzt protokolliert: 15:47:21
home-assistant-voice-0915f6 @ (placeholder for IP address): Connection error occurred: home-assistant-voice-0915f6 @ (placeholder for IP address): Connection lost
And the second log entry:
Logger: aioesphomeapi.reconnect_logic
Erstmals aufgetreten: 15:45:32 (1 Vorkommnisse)
Zuletzt protokolliert: 15:45:32
Can't connect to ESPHome API for home-assistant-voice-0915f6 @ (placeholder for IP address): Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='(placeholder for IP address)', port=6053))]: [Errno 113] Connect call failed ('(placeholder for IP address)', 6053) (SocketAPIError)
I can see it connecting in my router so WiFi does not seem to be the problem.
:information_source:
Edit: Solved.
I had to make a firmware update to version 25.1.0 by connecting the Voice PE to my computer.
After the update and filling the wifi credentials it worked again.
