Home Assistant Voice PE No Option to Change Wifi SSID
Dear Home Assistant Community,
I’m encountering connectivity issues with my Home Assistant Voice PE.
  • Scenario:
    • Home Assistant Voice PE is connected to an existing Wi-Fi network.
    • This Wi-Fi network and its SSID reside on a different subnet than my Home Assistant instance.
  • Current Behavior:
    • Limited functionality: I can only control the LED ring on/off.
    • Voice Assistant setup fails due to the inability to reach the Home Assistant Voice PE.
  • Troubleshooting Steps:
    • I created a new Wi-Fi SSID and VLAN with the same subnet as my Home Assistant instance.
    • Unfortunately, there appears to be no option to:
      • Reset the Home Assistant Voice PE to factory defaults.
      • Re-configure the Voice PE to connect to a different SSID.
  • System Information:
    • Home Assistant Voice PE by Nabu Casa
    • Firmware: 25.1.0 (ESPHome 2024.12.2)
I’m seeking guidance on how to resolve this connectivity issue and successfully integrate the Voice PE into my Home Assistant environment.
Did you try this?
Resetting the device – Home Assistant Voice Preview Edition
thanks a lot .)
i just got two voice assistants and i tried to add both and both failed the setup and are now stuck on a white light and i can not reset either or…any ideas?
