Home Assistant Voice Preview Edition with Display
I also modified the STL files to make holes for the speaker (bottom and case), as well as a way to hold the screen cover without glue.
I used this screen from Amazon US
With this pin config:
| ST7735 Pin  | ESP32 Pin       | ESP32 Board Label   | Description                |
| GND         | GND (IO47)      | IO47 (Top-left )    | Ground                     |
| VCC         | 3.3V            | 3.3V                 | Power                     |
| SCL (SCK)   | GPIO40          | IO40                 | SPI Clock (SCK)           |
| SDA (MOSI)  | GPIO41          | IO41                 | SPI Data (MOSI)           |
| RES         | GPIO42          | IO42                 | Reset                     |
| DC          | GPIO01          | IO01                 | Data/Command              |
| CS          | GPIO48          | IO48                 | Chip Select               |
| BL          | GPIO02          | IO02                 | Backlight Control (On/Off)|
