Home Assistant wanting to downgrade from 0.108.7 to 0.108.6
Hi there, Home Assistant is telling me to downgrade the core version for some reason… I’ve tried to restart HA but this message is still here. Should I wait until the next update or just leave it alone?
See the attached image
Same here. I downgraded because 108.7 wasn’t able to connect to Nabu Casa
I’m currently running this locally without Nabu Casa right now, just wondering why it tells me to downgrade… It might be because the devs have to fix something with HA Core 0.108.7
I have the same issue here. And remote connection doesn’t work.
Same here. Not running Nabu casa, on local RPI3.
0.108.8 coming already:
Release 0.108.8 - April 22
Check your Private Messages for the code you asked for :slight_smile:
same problem here. updated to 0.108.7 and now it shows update available to 0.108.6
The developers just pushed an update for this bug. You might need to wait a bit to receive the update version 0.108.8.
Quote from @Piggyback
