Home Assistant WebUI wont start
today i waked up and home assistant wont work anymore. i cant reach the webui. So i restarted but it still wont work. So i looked a little bit over the CLI with core logs, supervisor logs. uses different repair options. but i diddt help. so i restored proxmox backups from the last 2 weeks and no backup start up. know i installed haos new and restored from my last backup from yesterday. now home assistant starts, load the integration and after it loaded a few integrations it doesnt react anymore.
Now i need help. i have no idea which integration stops ha from working. is there any log file i can see it? in core logs i see only things like: that ha dont reach some server and that the hacs integration not tested. when i want to restart i get the error that there is a job running… (Error: Another job is running for job group home_assistant_core") but i have no idea which job it is.
what can i do? i would like to prevent all integrations from starting up, and start one integration after the other.
thank you very much for your help
strauch
Same here. Same problems and error. HA is connected to my home network, I can see it on my modem but cannot connect anymore. It is running.
Ok, i got a step further. I creted an empty file in the configuration folder (where the configuration.yaml files stored) with the name safe-mode after a restart. ha starts without the integratins. now i can start one integration after another. this will take a while because i make a restart of home assistant after every deactivation.
Mhh it seems to be entso-e again :frowning:
Same issue here. tried resetting the HA yellow, but still not able to connect?
How did you get the file created in that location?
Or any possibility to remove entso-e from the commandline?
Same problem here. Also entso-e installed…
Same boat! Any fix? Are you sure it’s Entso? I’m now at least back in safe mode
@jongbj via the CLI , enter “login” then “Couch safe-mode”
But I found that directly after a restart of the host and the CLI loads, you can type "
core restart --safe-mode"
If you wait too long, it does not work
UPDATE: I can confirm that this is the issue. Disable this Add on and all back.
I had the same issue and i can confirm that after deleting the Entsoe integration evrything works again. Thanks for the info.
Thank you. I was able to remove the integration completely which solved the problem. Too bad I already spent hours trouble-shooting, but at least we’re up and runnin again.
I’ve decided to remove entso-e and switch to Nordpool. Entso-e has crashed the entire system twice now. Both times, it’s cost me significant data loss and time.
