Im hoping someone here can help. I currently have Docker running on an Ubuntu Server 18.04. I have Traefik, Home Assistant and Portainer (all running the latest versions) running at the moment. I have Traefik setup with my DuckDNS account and its set up successfully with Lets Encrypt. The trouble Im having is that the HA page doesnt load fully when attempting to access it from the DuckDNS url. I am able to access Traefik’s front end just from from the url, but when I attempt to access HA the only thing that loads is the blue bar across the top. I checked the logs in HA but there wasnt anything that talked about blocked access. Im not sure what else to check. Ill post my configs below
docker-compose.yml
version: "3.6"
services:
portainer:
image: portainer/portainer
container_name: portainer
restart: always
command: -H unix:///var/run/docker.sock
ports:
- "9000:9000"
volumes:
- /var/run/docker.sock:/var/run/docker.sock
- ${USERDIR}/Docker/portainer/data:/data
- ${USERDIR}/Docker/shared:/shared
environment:
- TZ=${TZ}
homeassistant:
container_name: homeassistant
restart: always
image: homeassistant/home-assistant
volumes:
- ${USERDIR}/Docker/homeassistant:/config
- /etc/localtime:/etc/localtime:ro
ports:
- "8123:8123"
privileged: true
environment:
- PUID=${PUID}
- PGID=${PGID}
- TZ=${TZ}
networks:
- traefik_proxy
- default
labels:
- "traefik.enable=true"
- "traefik.backend=homeassistant"
- "traefik.frontend.rule=Host:${DOMAINNAME}; PathPrefixStrip: /homeassistant"
- "traefik.port=8123"
- "traefik.docker.network=traefik_proxy"
- "traefik.default.protocol=http"
- "traefik.frontend.headers.SSLRedirect=true"
- "traefik.frontend.headers.STSSeconds=315360000"
- "traefik.frontend.headers.browserXSSFilter=true"
- "traefik.frontend.headers.contentTypeNosniff=true"
- "traefik.frontend.headers.forceSTSHeader=true"
- "traefik.frontend.headers.SSLHost=example.com"
- "traefik.frontend.headers.STSIncludeSubdomains=true"
- "traefik.frontend.headers.STSPreload=true"
- "traefik.frontend.headers.frameDeny=true"
traefik:
hostname: traefik
image: traefik:latest
command: --api --docker
container_name: traefik
restart: always
domainname: ${DOMAINNAME}
networks:
# - default
- traefik_proxy
ports:
- "80:80"
- "443:443"
- "8080:8080"
environment:
- DUCKDNS_TOKEN=${DUCKDNS_TOKEN}
labels:
- "traefik.backend=traefik"
- "traefik.frontend.rule=Host:${DOMAINNAME}; PathPrefixStrip: /traefik"
- "traefik.port=8080"
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
- ${USERDIR}/Docker/traefik:/etc/traefik
networks:
traefik_proxy:
external:
default:
driver: bridge
traefik.toml
logLevel = "DEBUG" #DEBUG, INFO, WARN, ERROR, FATAL, PANIC
defaultEntryPoints = ["https", "http"]
[api]
entryPoint = "traefik"
dashboard = true
address = ":8080"
usersFile = "/shared/.htpasswd"
# Force HTTPS
[entryPoints]
[entryPoints.http]
address = ":80"
[entryPoints.http.redirect]
entryPoint = "https"
[entryPoints.https]
address = ":443"
[entryPoints.https.tls]
[retry]
[file]
watch = true
filename = "/etc/traefik/rules.toml"
# Let's encrypt configuration
[acme]
email = "EMAIL"
storage = "/etc/traefik/acme/acme.json"
acmeLogging = true
# onDemand = false #create certificate when container is created
onHostRule = true
# Use a HTTP-01 acme challenge rather than TLS-SNI-01 challenge
[acme.httpChallenge]
entryPoint = "http"
[[acme.domains]]
main = "MY_DOMAIN.duckdns.org"
# Connection to docker host system (docker.sock)
[docker]
endpoint = "unix:///var/run/docker.sock"
domain = "MY_DOMAIN.duckdns.org"
watch = true
# This will hide all docker containers that don't have explicitly
# set label to "enable"
exposedbydefault = false
EDIT: I also tried re-creating the containers with all the - "traefik.frontend.headers.
commented out but that didnt change anything.
cwhits
(Chris Helming)
December 23, 2018, 1:33pm
2
I’m in the middle of setting this up right now to get rid of another box so I’m not at the HASS portion yet. But… you should switch your [acme]
section around so you pull a wildcard cert for your duckdns domain.
[acme]
email = "[email protected] "
storage="/etc/traefik/acme/acme.json"
acmeLogging=true
[acme.dnsChallenge]
provider = "duckdns"
delayBeforeCheck = 0
[[acme.domains]]
main = "*.yourdomain.duckdns.org"
sans = ["yourdomain.duckdns.org"]
piotr
(Peter)
March 4, 2019, 3:35pm
3
letroll
(Julien)
August 11, 2019, 10:03pm
4
Hello, @fletch8527 did you find a solution? I am in the same situation as you
Yea, I solved me issue by getting a SmartThings hub instead lol. I was using HA so that I could get Google Assistant integration. I later found that I would need to restart the Google App monthly to keep the integration (I didnt pay the subscription for HA) and that was enough to push me to get something that supported the integration without a monthly fee.
Sorry I couldnt be any more help
letroll
(Julien)
August 13, 2019, 10:18am
6
Anyway you have take time to answer me I’ll share my result of I succeed
azrael783
(Daniel)
September 2, 2019, 1:08pm
7
I tested a traefik / homeassistant / portainer setup with the following setting:
traefik.toml:
debug = false
logLevel = "INFO"
defaultEntryPoints = ["https","http"]
[entryPoints]
[entryPoints.http]
address = ":80"
[entryPoints.https]
address = ":443"
[entryPoints.traefik]
address = ":8080"
[retry]
[api]
debug = true
[docker]
domain = "yourdomain.de"
watch = true
exposedByDefault = false
[acme]
storage = "acme.json"
onHostRule = true
entryPoint = "http"
docker-compose.yml for traefik:
version: '2'
services:
traefik:
restart: always
ports:
- 80:80
- 443:443
- 8080:8080
networks:
- web
volumes:
- /var/opt/traefik/traefik.toml:/traefik.toml
- /var/opt/traefik/acme.json:/acme.json
portainer:
image: portainer/portainer:latest
restart: always
ports:
- 9000:9000
networks:
- web
volumes:
- /var/opt/portainer:/data
labels:
- "traefik.backend=portainer"
- "traefik.frontend.rule=Host:yourdomain.de" # URL entsprechend anpassen!
- "traefik.port=9000"
- "traefik.docker.network=web"
networks:
web:
external: true
and last but not least the docker-compose.yml for homeassistant:
version: '2'
services:
homeassistant:
container_name: home-assistant
image: homeassistant/home-assistant:stable
volumes:
- /var/opt/homeassistant/config:/config
environment:
- TZ=Europe/Berlin
restart: always
ports:
- 8123:8123
networks:
- web
labels:
- "traefik.frontend.rule=Host:subdomain.yourdomain.de" # URL entsprechend anpassen!
networks:
web:
external: true
This worked fine for me and will go live soon (right now I am still on NGINX, but I find traefik way more easy). I don’t use duckdns, I have my own domain (from Strato).
100lv
(100lv)
January 5, 2020, 10:00am
8
Here is my config - based on Traefik 2.x with DuckDNS and LetsEncrypt.
reverse-proxy:
# The official v2.0 Traefik docker image
container_name: reverse_proxy
# Enables the web UI and tells Traefik to listen to docker
command: --api.insecure=true --providers.docker --entrypoints.web.address=:80 --entrypoints.websecure.address=:443 [email protected] --certificatesresolvers.le.acme.storage=/acme.json --certificatesresolvers.le.acme.dnschallenge=true --certificatesresolvers.le.acme.dnschallenge.provider=duckdns --metrics.prometheus=true --metrics.prometheus.buckets="0.100000, 0.300000, 1.200000, 5.000000" --metrics.prometheus.entrypoint='metrics' --metrics.prometheus.addEntryPointsLabels=true --metrics.prometheus.addServicesLabels=true --entryPoints.metrics.address=:8282
homeassistant:
image: homeassistant/home-assistant:latest
restart: always
ports:
- 8123:8123
volumes:
- /opt/docker/home-assistant:/config
links:
- mysql
- ha_dockermon
labels:
- traefik.http.routers.homeassistant.entrypoints=websecure
- traefik.http.routers.homeassistant.rule=Host(`ha.xxxxx.duckdns.org`)
- traefik.http.services.homeassistant.loadbalancer.server.port=8123
- traefik.http.routers.homeassistant.tls.certresolver=le
sj3fk3
(Greg)
January 11, 2020, 10:30am
9
Just curious… Why are you giving hass access to your docker socket?
100lv
(100lv)
January 11, 2020, 9:23pm
10
[quote=" [sj3fk3], post:9, topic:85738"]
[/quote]
Because I’m sleeping … Copy/paste error thanks!
azrael783
(Daniel)
February 10, 2020, 8:18pm
11
This works also for me, but I have added a fixed IP address to both containers in order to use the ip-ban-list from HA. Here is my code:
version: '3.3'
services:
traefik:
command:
#- "--log.level=DEBUG"
- "--api.insecure=true"
- "--providers.docker=true"
- "--providers.docker.exposedbydefault=false"
- "--entrypoints.web.address=:80"
- "--entrypoints.websecure.address=:443"
- "--certificatesresolvers.myhttpchallenge.acme.httpchallenge=true"
- "--certificatesresolvers.myhttpchallenge.acme.httpchallenge.entrypoint=web"
#- "--certificatesresolvers.myhttpchallenge.acme.caserver=https://acme-staging-v02.api.letsencrypt.org/directory"
- "--certificatesresolvers.myhttpchallenge.acme.email=webmaster@yourdomain.de"
- "--certificatesresolvers.myhttpchallenge.acme.storage=/acme.json"
ports:
- 80:80
- 443:443
- 8080:8080
networks:
web:
ipv4_address: 172.30.0.2
volumes:
homeassistant:
image: homeassistant/home-assistant:0.104.3
volumes:
- /home/daniel/docker/homeassistant/config:/config
environment:
- TZ=Europe/Berlin
restart: unless-stopped
ports:
- 8123:8123
networks:
web:
ipv4_address: 172.30.0.3
labels:
- "traefik.http.routers.homeassistant.rule=Host(`yourdomain.homeassistant.de`)"
- "traefik.http.routers.homeassistant.entrypoints=websecure"
- "traefik.http.routers.homeassistant.tls.certresolver=myhttpchallenge"
- "traefik.http.services.homeassistant.loadbalancer.server.port=8123"
networks:
web:
driver: bridge
ipam:
driver: default
config:
- subnet: 172.30.0.0/24
And in configuration.yaml:
http:
base_url: http://yourdomain.homeassistant.de
use_x_forwarded_for: true
trusted_proxies: 172.30.0.2
ip_ban_enabled: true
login_attempts_threshold: 3
