Home Assistant with IPv6 (DS-Lite) and Duckdns
Hi!
I have changed my internet provider. And now I’m connected over DS-Lite with an IPv6 adress.
I have some questions to to get external access to home assistant without the nabu casa cloud solution.
Do I only need run the Duckdns Hass.io addon? Or also the Duckdns DynDNS entry in my router (Fritzbox)?
Or is there no need for duckdns because of IPv6?
Thank you
Hi Marius,
as far as I have tried it will not work with DS Lite. Technically I can’t explain right now but it is currently not possible with the Fritzbox OS / Unitymedia combination (I guess you have this setup). As far as I have tried only nabu casa works to remotely access my HA instance.
