fsuk
April 28, 2026, 7:25pm
1
Anyone managed to get ESPHome or any sort of Home Assistant integration on the Seeed D1001?
I couldn’t figure out how to configure ESP Home for it as it seems the board/vender isn’t yet fully supported with a default config.
I’m looking into ESP-IDF and coding a custom app and will post updates if I’m succesfull
fsuk
April 29, 2026, 8:55pm
2
Looks like there is some development for the D1001 and ESPHome going on
next ← clydebarrow:seeed-d1001
opened 11:19AM - 20 Apr 26 UTC
## Description
**Related issue (if applicable):** fixes <link to issue>
**… Pull request in [esphome](https://github.com/esphome/esphome) with YAML changes (if applicable):**
- esphome/esphome#15867
## Checklist
- [x] I am merging into `next` because this is new documentation that has a matching pull-request in [esphome](https://github.com/esphome/esphome) as linked above.
or
- [ ] I am merging into `current` because this is a fix, change and/or adjustment in the current documentation and is not for a new component or feature.
- [ ] Link added in `/src/content/docs/components/index.mdx` when creating new documents for new components or cookbook.
<details>
<summary><strong>New Component Images</strong></summary>
If you are adding a new component to ESPHome, you can automatically generate a standardized black and white component name image for the documentation.
**To generate a component image:**
1. Comment on this pull request with the following command, replacing `component_name` with your component name in **lower_case** format with **underscores** (e.g., `bme280`, `sht3x`, `dallas_temp`):
@esphomebot generate image component_name
2. The ESPHome bot will respond with a downloadable ZIP file containing the SVG image.
3. Extract the SVG file and place it in the `/public/images/` folder of this repository.
4. Use the image in your component's index table entry in `/src/content/docs/components/index.mdx`.
**Example:** For a component called "DHT22 Temperature Sensor", use:
@esphomebot generate image dht22
**Note:** All images used in ImgTable components must be placed in `/public/images/` as the component resolves them to absolute paths.
</details>
fsuk
April 29, 2026, 11:05pm
3
With a bit of help from Claude and the latest dev release of the ESPHome builder I have managed to get the screen to boot and display some text.
Disclaimer, I not an expert of this, potentially incorrect settings could damage your device, use at own risk
Some configuration may be redundant, I need to go back through and clean up.
Not sure if network is working yet
esphome:
friendly_name: reTerminal D1001
on_boot:
priority: 800
then:
- output.turn_on: lcd_pwr_en
- output.turn_on: en_lcd_pwr
- output.set_level:
level: 100%
esp32:
board: esp32-p4
framework:
type: esp-idf
version: recommended
advanced:
enable_idf_experimental_features: true
ignore_efuse_mac_crc: false
sdkconfig_options:
CONFIG_LV_ATTRIBUTE_FAST_MEM: "y"
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: "n"
CONFIG_SPIRAM_RODATA: "n"
CONFIG_ESP32P4_CACHE_L2_CACHE_SIZE_512KB: "y"
CONFIG_MIPI_DSI_USES_PSRAM: "n"
flash_size: 32MB
psram:
speed: 100MHz
logger:
hardware_uart: USB_SERIAL_JTAG
level: DEBUG
esp_ldo:
- channel: 3
voltage: 2.5V
i2c:
- id: i2c_lcd
sda: GPIO37
scl: GPIO38
scan: true
frequency: 400kHz
- id: i2c_misc
sda: GPIO20
scl: GPIO21
scan: false
frequency: 400kHz
xl9535:
- id: xl9535_hub
i2c_id: i2c_misc
address: 0x20
output:
- platform: gpio
pin:
xl9535: xl9535_hub
number: 0 # LCD_PWR_EN
- platform: gpio
pin:
xl9535: xl9535_hub
number: 7 # EN_LCD_PWR
- platform: ledc
pin: GPIO14 # LCD_PWMc
frequency: 1000Hz
light:
- platform: monochromatic
output: lcd_backlight_pwm
name: "Display Backlight"
restore_mode: ALWAYS_ON
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "reTerminal Fallback"
api:
encryption:
key: !secret api_key
esp32_hosted:
variant: esp32c6
clk_pin: GPIO11
cmd_pin: GPIO6
reset_pin: GPIO13
d0_pin: GPIO7
d1_pin: GPIO8
d2_pin: GPIO9
d3_pin: GPIO10
active_high: false
ota:
- platform: esphome
# binary_sensor:
# - platform: gpio
# pin:
# number: GPIO35
# mode: INPUT_PULLUP
# inverted: true
# name: "Boot Button"
# id: boot_button
display:
- platform: mipi_dsi
model: SEEED-RETERMINAL-D1001
auto_clear_enabled: false
update_interval: never
lvgl:
displays:
- main_display
color_depth: 16
draw_rounding: 2
buffer_size: 10%
full_refresh: false
theme:
label:
text_color: 0xFFFFFF
bg_color: 0x1a1a2e
pages:
- id: main_page
widgets:
- label:
text: "reTerminal D1001"
align: CENTER
text_font: MONTSERRAT_48
fsuk
April 30, 2026, 8:48am
4
Ok some more progress
Wifi is working and also power button toggles the display on/off
Some color issues, by default the color orders seems to be BRG (not RGB or BGR) i suspect this is an issue with the display driver (which is still experimental), i have tried color_order and invert_colors but these give other odd results
esphome:
on_boot:
priority: 800
then:
- output.set_level:
level: 100%
esp32:
board: esp32-p4
cpu_frequency: 360MHz
framework:
type: esp-idf
advanced:
sdkconfig_options:
# CONFIG_LV_ATTRIBUTE_FAST_MEM: "y"
# CONFIG_SPIRAM_FETCH_INSTRUCTIONS: "n"
# CONFIG_SPIRAM_RODATA: "n"
# CONFIG_MIPI_DSI_USES_PSRAM: "n"
flash_size: 32MB
psram:
speed: 100MHz
logger:
level: DEBUG
esp_ldo:
- channel: 3
voltage: 2.5V
i2c:
- id: i2c_lcd
sda: GPIO37
scl: GPIO38
scan: true
frequency: 400kHz
- id: i2c_misc
sda: GPIO20
scl: GPIO21
scan: false
frequency: 400kHz
xl9535:
- id: xl9535_hub
i2c_id: i2c_misc
address: 0x20
output:
- platform: gpio
pin:
xl9535: xl9535_hub
- platform: gpio
pin:
xl9535: xl9535_hub
- platform: ledc
frequency: 1000Hz
light:
wifi:
api:
encryption:
esp32_hosted:
variant: esp32c6
clk_pin: GPIO11
cmd_pin: GPIO6
reset_pin: GPIO13
d0_pin: GPIO7
d1_pin: GPIO8
d2_pin: GPIO9
d3_pin: GPIO10
active_high: true
ota:
- platform: esphome
binary_sensor:
- platform: gpio
pin:
number: GPIO35
mode: INPUT_PULLUP
inverted: true
- platform: gpio
pin:
number: GPIO3
mode: INPUT_PULLUP
inverted: true
on_press:
then:
- light.toggle: backlight
display:
lvgl:
displays:
- main_display
draw_rounding: 2
full_refresh: false
rotation: 270
bg_color: 0x000000
pages:
- id: main_page
bg_opa: COVER
widgets:
- label:
text: "RED"
align: TOP_MID
text_color: 0xFF0000
- label:
text: "GREEN"
align: CENTER
text_color: 0x00FF00
- label:
text: "BLUE"
align: BOTTOM_MID
text_color: 0x0000FF
fsuk
April 30, 2026, 5:33pm
5
The display test card works
I think it might be an issue with the display being 24bit and LVGL only supporting 16bit
fsuk
April 30, 2026, 5:47pm
6
Setting the lvgl byte_order: little_endian fixes the colours
esphome:
on_boot:
priority: 800
then:
- output.set_level:
level: 60%
esp32:
board: esp32-p4
framework:
type: esp-idf
advanced:
sdkconfig_options:
flash_size: 32MB
psram:
speed: 100MHz
logger:
level: DEBUG
esp_ldo:
- channel: 3
voltage: 2.5V
i2c:
- id: i2c_lcd
sda: GPIO37
scl: GPIO38
scan: true
frequency: 400kHz
- id: i2c_misc
sda: GPIO20
scl: GPIO21
scan: false
frequency: 400kHz
xl9535:
- id: xl9535_hub
i2c_id: i2c_misc
address: 0x20
output:
- platform: gpio
pin:
xl9535: xl9535_hub
- platform: gpio
pin:
xl9535: xl9535_hub
- platform: gpio
pin:
xl9535: xl9535_hub
number: 12 # TP_RST
- platform: ledc
frequency: 1000Hz
light:
wifi:
api:
encryption:
esp32_hosted:
variant: esp32c6
clk_pin: GPIO11
cmd_pin: GPIO6
reset_pin: GPIO13
d0_pin: GPIO7
d1_pin: GPIO8
d2_pin: GPIO9
d3_pin: GPIO10
active_high: true
ota:
- platform: esphome
display:
globals:
- id: last_activity
type: int
restore_value: false
initial_value: '0'
- id: snow_colour
type: int
initial_value: '0'
lvgl:
draw_rounding: 2
full_refresh: false
rotation: 270
bg_color: 0x000000
pages:
- id: main_page
bg_opa: COVER
widgets:
- label:
text: "RED"
align: TOP_MID
- label:
text: "GREEN"
align: CENTER
- label:
text: "BLUE"
align: BOTTOM_MID
I’ll have the touchscreen working shortly.
fsuk
May 1, 2026, 6:38am
8
Awesome, thanks for your work.
Here's a config that demonstrates the display, touchscreen, accelerometer, battery charge.
fsuk
May 8, 2026, 2:29pm
11
Thanks for your hard work!
I've done some testing with your config and mine and the display, touch, motion and battery all seem to work great.
The only minor issue I found (using your config) was the power hold to power off is not working, the button/binary sensor is raising an event so I think its either the condition or the script.
fsuk
May 8, 2026, 2:35pm
12
Never mind!
Power off button only works when running on battery.
This thread was super helpful in getting custom firmware working on my LuxWX platform. Thank you!!
alva
(alva)
August 1, 2026, 6:55pm
15
Thanks for all your work, i got audio and speakers with there dac and adc working, and added the rtc.
But i have no idea about the cam.
Maybe it will helpfull to someone else.
substitutions:
friendly_name: Seeed Studio D1001
esphome:
friendly_name: ${friendly_name}
on_boot:
priority: 15.0
then:
- light.turn_on:
brightness: 15%
esp32:
variant: esp32p4
engineering_sample: true
flash_size: 32MB
framework:
type: esp-idf
advanced:
execute_from_psram: false
logger:
level: debug
psram:
speed: 200MHz
debug:
api:
encryption:
key: !secret seed_d1001__encryption_key
web_server:
version: 3
http_request:
esp_ldo:
- channel: 3
voltage: 2.5V
esp32_hosted:
variant: ESP32C6
reset_pin: GPIO13
cmd_pin: GPIO6
clk_pin: GPIO11
d0_pin: GPIO7
d1_pin: GPIO8
d2_pin: GPIO9
d3_pin: GPIO10
active_high: true
xl9535:
i2c_id: misc_i2c
ota:
- platform: esphome
password: !secret seed_d1001__ota_password
on_begin:
then:
- light.turn_off: lcd_backlight
wifi:
display:
light:
output: backlight_output
name: LCD Backlight
default_transition_length: 0s
gamma_correct: 1.0
output:
- platform: ledc
pin: 14
frequency: 1220Hz
inverted: false
#min_power: 15%
i2c:
- id: lcd_i2c
sda:
ignore_strapping_warning: true
number: GPIO37
scl:
number: GPIO38
scan: true
frequency: 400kHz
- id: misc_i2c
sda: GPIO20
scl: GPIO21
scan: true
frequency: 400kHz
lvgl:
rotation: 270
style_definitions:
- id: circle
radius: circle
outline_width: 2
outline_color: grey
align: center
- id: dashline
width: 100%
height: 100%
line_dash_width: 5
line_dash_gap: 5
line_color: grey
- id: cardinals
text_font: montserrat_40
on_pressing:
- lvgl.widget.update:
x: !lambda 'return point.x - 18;'
y: !lambda 'return point.y - 6;'
top_layer:
widgets:
- label:
hidden: true
text: "Powering off"
align: center
bg_color: darkgrey
bg_opa: cover
text_color: white
text_align: center
width: 50%
- label:
align: top_right
x: -60
text_font: montserrat_16
text: "Press and hold green button to power off"
widgets:
- container:
layout: vertical
align: left_mid
pad_all: 20px
height: 50%
width: 20%
widgets:
- button:
width: size_content
widgets:
- label:
text_font: montserrat_24
align: center
text: Charge Enabe
checkable: true
pad_all: 10px
on_value:
- switch.control:
state: !lambda return x;
- delay: 200ms
- component.update: vbat
- label:
text_align: center
text: "--"
pad_all: 10px
- label:
text_align: center
text: "--"
pad_all: 10px
- container:
width: 400
height: 400
align: center
styles: [circle, cardinals]
bg_color: lightgreen
bg_opa: cover
widgets:
- container:
styles: circle
width: 75%
height: 75%
- container:
styles: circle
width: 50%
height: 50%
- container:
styles: circle
width: 25%
height: 25%
- line:
styles: dashline
- 50%,0
- 50%,100%
- line:
styles: dashline
- {x: 0, y: 50%}
- [100%, 50%]
- container:
styles: circle
width: 8%
height: 8%
bg_color: grey
bg_opa: 50%
- label:
text: R
align: bottom_mid
- label:
text: F
align: top_mid
- label:
text: L
align: left_mid
- label:
text: R
align: right_mid
- container:
styles: circle
width: 10%
height: 10%
bg_color: tomato
bg_opa: 100%
x: 100
y: 100
# Red dot that follows touch
- obj:
event_bubble: true
scrollable: false
x: 154
y: 114
width: 36
height: 36
bg_color: blue
bg_opa: COVER
border_width: 0
radius: circle
script:
- id: power_down_script
mode: single
then:
- lvgl.label.update:
hidden: false
text: "Powering off in 3s"
- delay: 1s
text: "Powering off in 2s"
- delay: 1s
text: "Powering off in 1s"
- delay: 1s
text: "Powering off now"
- delay: 500ms
- switch.turn_off: power_hold
- id: update_id
then:
- if:
condition:
lambda: return abs(id(roll_id).state) < 1.0f && abs(id(pitch_id).state) < 1.0f;
then:
lvgl.widget.update:
bg_color: green
x: !lambda return (int)(clamp(id(roll_id).state, -20.0f, 20.0f) / 20.0f * 200);
y: !lambda return (int)(clamp(id(pitch_id).state, -20.0f, 20.0f) / 20.0f * 200);
else:
lvgl.widget.update:
bg_color: red
motion:
- platform: lsm6ds
accelerometer_range: 4G
gyroscope_range: 2000DPS
i2c_id: misc_i2c
update_interval: 50ms
axis_map:
x: -y
y: x
z: -z
switch:
- platform: gpio
name: Battery Charge Enable
pin:
xl9535:
number: 12
inverted: true
on_state:
lvgl.widget.update:
state:
checked: !lambda return x;
- platform: gpio
pin:
xl9535:
number: 10
restore_mode: RESTORE_DEFAULT_ON
- platform: gpio
pin:
xl9535:
number: 6
- platform: gpio
name: "D1001 Speaker Amplifier"
pin:
xl9535: expander
number: 13 # Pin 13 steuert beim D1001 den NS4150B Verstärker
mode: OUTPUT
restore_mode: ALWAYS_ON # Schaltet den Verstärker direkt beim Start ein
binary_sensor:
- platform: gpio
pin: 3
trigger_on_initial_state: false
on_press:
if:
condition:
binary_sensor.is_off: vsys_power_good
then:
script.execute: power_down_script
on_release:
- delay: 300ms
- script.stop: power_down_script
hidden: true
- switch.turn_on: power_hold
- platform: gpio
pin:
number: 4
inverted: true
mode: INPUT_PULLUP
name: VSYS Power Good
touchscreen:
- platform: gsl3670
i2c_id: lcd_i2c
model: seeed-reterminal-d1001
- platform: adc
pin: 18
update_interval: 10s
attenuation: auto
filters:
- multiply: 2.0
on_value:
lvgl.label.update:
text:
format: "Bat %.2fV"
args: [x]
- platform: motion
type: acceleration_x
accuracy_decimals: 2
filters:
- sliding_window_moving_average:
window_size: 4
send_every: 4
- platform: motion
type: acceleration_y
filters:
window_size: 4
send_every: 4
- platform: motion
type: acceleration_z
filters:
window_size: 4
send_every: 4
# Gyroscope axes (unit: °/s)
- platform: motion
type: gyroscope_x
filters:
window_size: 4
send_every: 4
- platform: motion
type: gyroscope_y
filters:
window_size: 4
send_every: 4
- platform: motion
type: gyroscope_z
filters:
window_size: 4
send_every: 4
- platform: motion
type: angular_rate_x
name: "Angular Rate X"
filters:
window_size: 4
send_every: 4
- platform: motion
type: angular_rate_y
name: "Angular Rate Y"
filters:
window_size: 4
send_every: 4
- platform: motion
type: angular_rate_z
name: "Angular Rate Z"
filters:
window_size: 4
send_every: 4
- platform: motion
type: pitch
filters:
window_size: 4
send_every: 1
- platform: motion
type: roll
filters:
window_size: 4
send_every: 1
on_value:
script.execute: update_id
- platform: wifi_signal
- platform: uptime
- platform: sound_level
passive: false
peak:
rms:
time:
- platform: homeassistant
timezone: Europe/Berlin
on_time_sync:
then:
# ... and update the RTC when the synchronization was successful
pcf8563.write_time:
- platform: pcf8563
i2c_id: misc_i2c
update_interval: 15min
audio_adc:
- platform: es7210
i2c_id: misc_i2c
i2s_audio:
- id: mic_i2s_bus
i2s_mclk_pin: GPIO29
i2s_bclk_pin: GPIO28
i2s_lrclk_pin: GPIO27
- id: speaker_i2s_bus
i2s_mclk_pin: GPIO33
i2s_bclk_pin: GPIO32
i2s_lrclk_pin: GPIO31
microphone:
- platform: i2s_audio
i2s_audio_id: mic_i2s_bus
i2s_din_pin: GPIO26
adc_type: external
audio_dac:
- platform: es8311
i2c_id: misc_i2c
speaker:
dac_type: external
i2s_dout_pin: GPIO30
i2s_audio_id: speaker_i2s_bus
audio_dac: dac
- platform: mixer
output_speaker: speaker_i2s_audio_1
source_speakers:
- id: announcement_spk_mixer_input
- id: media_spk_mixer_input
- platform: resampler
output_speaker: media_spk_mixer_input
output_speaker: announcement_spk_mixer_input
media_player:
- platform: speaker
name: "Speaker Media Player"
media_pipeline:
speaker: media_spk_resampling_input
num_channels: 2
announcement_pipeline:
speaker: announcement_spk_resampling_input
num_channels: 1
fsuk
August 14, 2026, 12:38pm
16
Just tried to make some changes and it will no longer compile (due to a recent update I expect)
Platform missing. You must include one of the available platform keys: libretiny, nrf52, host, rp2, rtl87xx, ln882x, esp8266, bk72xx.
Note that esp32 is not listed as a platform in the error.
fsuk
August 14, 2026, 12:59pm
17
With a bit of AI help I have fixed the error
The source of your Platform missing error is that your substitutions: block has network configurations (wifi: and api:) nested directly inside it. ESPHome interprets these definitions as immediate instructions to look for wireless hardware on the core chip. Because the ESP32-P4 lacks a radio, it drops down to a fallback error parsing routine [esp32.com ]. [1 ]
I had this:
substitutions:
backlight_level: 60%
wifi:
api:
encryption:
wifi: ${wifi}
api: ${api}
Removing wifi and api from the substitutions and setting them directly fixes the issue
fsuk
August 14, 2026, 1:42pm
18
I have uploaded my full YAML to github
ESPHome Example Dashboard Config For Seeed D1001
