Home Assistant wont connect to Myenergi
Hi All
I’m trying to integrate Myenergi into my Home Assistant. When i go to configure the serial number and API key i get an error saying “Could not connect to myenergi, please try again in a while”
Any ideas what’s causing the issue, i have searched the forum and also google and cant seem to find any similar issues, so not sure if its something silly that I’m just doing wrong.
Fixed it i was putting in the wrong formatted serial number :frowning:
Hi Paul
Mind telling me what the correct format is please? Having the same problem.
I have got the same problem in here.
The serial number in my case is 209xxxx4
The api key is way longer but also this i wrote down.
Message showing is
Having the above issue today, all was working fine until today when everything went offline. Tried removing and re adding but get this error
Screenshot 2023-12-05 at 9.49.12 AM
Having the exact same issue this morning. Installed the myenergi integration last night and this morning was not working.
I deleted the integration and went to reinstall but could got the error “Could not connect to myenergi, please try again in a while”. Might be a server issue.
Interestingly I can access the my energy app through my cellular data, but not my wifi. Hopefully it will come good in a few hours.
Yes exactly the same for me ie app etc all works fine just not home assistant
