Installing HA on a MacMini Catalina 10.15.7 (16gig of ram), Virtualbox 7.0.4, using the haos_ova-9.4.vdi vdisk.
Removed and started over 2x…same results.
Settings - Linux 2.6/3.x/4.x/5.x 64bit
Clipboard disabled d/d disabled
4Gig Memory
Chipset PIIX3
TPM none
PS/2 mouse
Enable I/o APIC, Enable Hardware Clock in UTC, Enable EFI all checked
Enable Secure boot - unchecked
2 vCPU’s
Network
Bridge Adapter
en0 - hardware ethernet
Adapter type - Intel Pro/1000 MT Desktop (82540em)
Promiscuous mode - deny
Normal start - all green OK
Jumps to rebooting from rescue
All green OK
You are in rescue mode
few second later
Waiting for Home Assist cli to be ready
Get the welcome
1-2mins Waiting for Supervisor to startup
Displays system info and ha> prompt
Get to website
Says preparing HA
within 5mins - VM crashes and restarts - over and over
Here are excerpts from the log VM log files where errors occur…any clues?
00:00:04.910363 ERROR [COM]: aRC=VBOX_E_VM_ERROR (0x80bb0003) aIID={4680b2de-8690-11e9-b83d-5719e53cf1de} aComponent={DisplayWrap} aText={Could not take a screenshot (VERR_NOT_SUPPORTED)}, preserve=false aResultDetail=-37
00:00:05.016918 Display::i_handleDisplayResize: uScreenId=0 pvVRAM=00007ff7e4900000 w=1024 h=768 bpp=32 cbLine=0x1000 flags=0x0 origin=0,0
00:00:05.226134 PS2K: Selected scan set 2
00:00:05.231321 EHCI: Hardware reset
00:00:05.231554 EHCI: USB Operational
00:00:05.351082 ATA: LUN#2: EXECUTE DEVICE DIAGNOSTIC, status 00
00:00:05.353592 GUI: UIMediumEnumerator: Medium-enumeration finished!
00:00:05.411352 AHCI#0: Reset the HBA
00:00:05.411394 VD#0: Cancelling all active requests
00:00:05.947065 EFI: VBoxDbg> loadimage64 ‘.efi’ 0xdd6e9000 LB 0x9a000
00:00:07.857374 EHCI: USB Suspended
00:00:07.857485 EHCI: Hardware reset
00:00:07.870446 EFI: debug point DXE_AP
00:01:03.581726 GUI: UICommon: Commit data request…
00:02:22.828792 Changing the VM state from ‘RUNNING’ to ‘RESETTING’
00:02:22.828917 GIM: KVM: Resetting MSRs
00:02:22.829087 PIT: mode=3 count=0x10000 (65536) - 18.20 Hz (ch=0)
00:02:22.831180 AHCI#0: Reset the HBA
00:02:22.831213 VD#0: Cancelling all active requests
00:02:23.082350 PIIX3 ATA: Ctl#0: finished processing RESET
00:02:23.082490 PIIX3 ATA: Ctl#1: finished processing RESET
00:02:23.082595 HDA: Codec reset
00:02:23.082643 HDA: Reset
00:02:23.082806 PDMR3Reset: after 253 ms, 1 loops: 1 async tasks - piix3ide/0
00:02:23.082857 TM: Aborting catch-up attempt on reset with a 228 245 148 ns lag on reset; new total: 228 245 148 ns
00:02:23.641130 Changing the VM state from ‘RESETTING’ to ‘RUNNING’
00:00:01.317733 PGM: pgmR3PoolInit: cMaxPages=0x900 cMaxUsers=0x1200 cMaxPhysExts=0x1200 fCacheEnable=true
00:00:01.391124 ERROR [COM]: aRC=VBOX_E_IPRT_ERROR (0x80bb0005) aIID={6ac83d89-6ee7-4e33-8ae6-b257b2e81be8} aComponent={ConsoleWrap} aText={The VBoxGuestPropSvc service call failed with the error VERR_HGCM_SERVICE_NOT_FOUND}, preserve=false aResultDetail=-2900
00:00:01.414860 GUI: UIMediumEnumerator: Medium-enumeration finished!
00:00:03.287016 TM: NEM overrides the /TM/TSCModeSwitchAllowed setting.
00:00:03.732022 EFI: debug point SEC_PREMEM
00:00:03.769349 ERROR [COM]: aRC=VBOX_E_VM_ERROR (0x80bb0003) aIID={4680b2de-8690-11e9-b83d-5719e53cf1de} aComponent={DisplayWrap} aText={Could not take a screenshot (VERR_NOT_SUPPORTED)}, preserve=false aResultDetail=-37
00:00:03.854223 ERROR [COM]: aRC=VBOX_E_VM_ERROR (0x80bb0003) aIID={4680b2de-8690-11e9-b83d-5719e53cf1de} aComponent={DisplayWrap} aText={Could not take a screenshot (VERR_NOT_SUPPORTED)}, preserve=false aResultDetail=-37
00:00:03.957556 GUI: UIMachineViewNormal::resendSizeHint: Restoring guest size-hint for screen 0 to 800x600
00:00:03.960978 GUI: HID LEDs sync is enabled
00:00:04.293495 EFI: VBoxDbg> loadimage64 ‘UsbMassStorageDxe.efi’ 0xddf97000 LB 0x3100
00:02:23.644263 EFI: debug point SEC_PREMEM
