Hi, I’m new to Hassio and there is alot to take in. I’ve installed Home assistant SDK and signed up for an account on Home assistant cloud that is working I believe, it says that I’m connected. I’ve managed to start the addon but didn’t try out that much but now it won’t start and there are errors in log. Can someone give me a hint about configuration.
- this is what in configuration.yaml
indent preformatted text by 4 spaces
Text to speech
tts:
- platform: google
- this is what in config for the addin
“client_secrets”: “google_assistant.json”,
“project_id”: null,
“model_id”: null
and this is what log shows
2019-01-23 15:48:06 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform syncthru
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/syncthru.py”, line 72, in setup_platform
if not test_syncthru(host):
File “/usr/local/lib/python3.6/site-packages/pysyncthru/init.py”, line 15, in test_syncthru
json_dict = demjson.decode(r.text)
File “/usr/local/lib/python3.6/site-packages/demjson.py”, line 5699, in decode
return_stats=(return_stats or write_stats) )
File “/usr/local/lib/python3.6/site-packages/demjson.py”, line 4915, in decode
raise errors[0]
demjson.JSONDecodeError: Can not decode value starting with character ‘<’
2019-01-23 15:53:16 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1878100336] Received invalid command: webhook/list
Any help appreciated
Regards Håkan
