Home Assistant Yellow all of a sudden not accessible via web or app, but can connect via serial console
Last night my POE powered HA Yellow with CM5 8GB no wifi, no MMC, running HAOS on a NVMe all of a sudden became inaccessible via web (hostname and IP) and the Android app on my phone. I rebooted it and it seems to boot properly (Red light steady, yellow and green heartbeat), but still could not access it via SSH, web or app.
I pulled it from my rack and conencted it to my W11 PC with a USB-C cable. After installing the latest CP210x drivers and it showed up in my device manager, but I could not get the terminal to connect. So I plugged in the network cable with POE and let it boot, then plugged the USB cable into it and I now have access to the serial console. I ran the command ha supervisor logs and I see a lot of green a few yellows and a chunk of red text. Unfortunately, I do not see why it is not loading HA, but is booting and responds to ping.
I see an error about NUT server not starting, but I do not have it configured on my system yet, only installed.
2025-04-07 14:13:42.006 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting…
2025-04-07 14:13:42.010 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_a0d7b954_nut application
2025-04-07 14:13:42.312 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package nut/aarch64 · GitHub with version 0.14.1
2025-04-07 14:13:47.981 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting…
# ha supervisor logs
2025-04-07 14:13:42.006 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting...
2025-04-07 14:13:42.312 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/nut/aarch64 with version 0.14.1
2025-04-07 14:13:47.981 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting...
2025-04-07 14:13:47.985 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_a0d7b954_nut application
2025-04-07 14:13:48.258 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/nut/aarch64 with version 0.14.1
2025-04-07 14:13:53.921 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting...
2025-04-07 14:13:53.924 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_a0d7b954_nut application
2025-04-07 14:13:54.203 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/nut/aarch64 with version 0.14.1
2025-04-07 14:13:59.902 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting...
2025-04-07 14:13:59.906 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_a0d7b954_nut application
2025-04-07 14:14:00.191 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/nut/aarch64 with version 0.14.1
2025-04-07 14:14:04.924 INFO (MainThread) [supervisor.core] Start Home Assistant Core
2025-04-07 14:14:04.935 INFO (SyncWorker_6) [supervisor.docker.manager] Starting homeassistant
2025-04-07 14:14:05.062 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-04-07 14:14:05.862 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting...
2025-04-07 14:14:05.867 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_a0d7b954_nut application
2025-04-07 14:14:06.178 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/nut/aarch64 with version 0.14.1
2025-04-07 14:14:08.950 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
2025-04-07 14:14:08.951 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-04-07 14:14:10.084 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-04-07 14:14:10.091 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2025-04-07 14:14:11.910 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting...
2025-04-07 14:14:11.913 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_a0d7b954_nut application
2025-04-07 14:14:12.197 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/nut/aarch64 with version 0.14.1
2025-04-07 14:14:12.773 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_core_silabs_multiprotocol application
2025-04-07 14:14:13.009 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-silabs-multiprotocol with version 2.4.5
2025-04-07 14:14:18.149 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting...
2025-04-07 14:14:18.152 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_a0d7b954_nut application
2025-04-07 14:14:18.444 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/nut/aarch64 with version 0.14.1
2025-04-07 14:14:24.138 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting...
2025-04-07 14:14:24.141 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_a0d7b954_nut application
2025-04-07 14:14:24.446 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/nut/aarch64 with version 0.14.1
2025-04-07 14:14:30.096 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Network UPS Tools is failed, restarting...
2025-04-07 14:14:30.100 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_a0d7b954_nut application
2025-04-07 14:14:30.395 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/nut/aarch64 with version 0.14.1
2025-04-07 14:14:36.078 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-1993' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:1589> exception=AddonsJobError('Rate limit exceeded, more than 10 calls in 0:30:00')>
  File "/usr/src/supervisor/supervisor/addons/addon.py", line 1603, in watchdog_container
    await self._restart_after_problem(event.state)
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 291, in wrapper
    raise on_condition(
        f"Rate limit exceeded, more than {self.throttle_max_calls} calls in {self.throttle_period(group_name)}",
supervisor.exceptions.AddonsJobError: Rate limit exceeded, more than 10 calls in 0:30:00
2025-04-07 14:15:13.474 WARNING (MainThread) [supervisor.addons.addon] core_silabs_multiprotocol is already running!
2025-04-07 14:15:15.214 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2025-04-07 14:15:15.214 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2025-04-07 14:15:15.215 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 1 add-ons
2025-04-07 14:15:15.245 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_core_configurator application
2025-04-07 14:15:15.563 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-configurator with version 5.8.0
2025-04-07 14:15:45.763 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2025-04-07 14:15:45.763 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-04-07 14:15:45.765 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2025-04-07 14:15:45.765 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-04-07 14:15:45.766 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-04-07 14:15:45.767 INFO (MainThread) [supervisor.core] Supervisor is up and running
2025-04-07 14:15:45.768 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-04-07 14:15:45.769 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-04-07 14:15:45.769 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-04-07 14:15:45.948 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-04-07 14:15:45.948 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-04-07 14:15:45.948 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-04-07 14:15:45.948 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-04-07 14:15:46.018 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-04-07 14:15:46.022 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2025-04-07 14:15:46.023 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2025-04-07 14:15:46.023 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2025-04-07 14:15:46.023 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-04-07 14:15:46.088 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-04-07 14:15:46.088 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-04-07 14:15:46.103 INFO (MainThread) [supervisor.host.services] Updating service information
2025-04-07 14:15:46.108 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-04-07 14:15:46.191 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-04-07 14:15:46.197 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-04-07 14:15:46.244 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-04-07 14:15:46.244 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-04-07 14:15:46.244 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-04-07 14:16:13.023 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Silicon Labs Multiprotocol to start, took more than 120 seconds
2025-04-07 14:16:24.274 WARNING (MainThread) [supervisor.addons.addon] core_silabs_multiprotocol is already running!
2025-04-07 14:44:20.842 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-04-07 15:13:28.955 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-04-07 15:13:28.956 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-04-07 15:13:28.957 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-04-07 15:13:28.957 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-04-07 15:13:28.957 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-04-07 15:13:29.032 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-04-07 15:13:29.033 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-04-07 15:13:29.033 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-04-07 15:13:29.033 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-04-07 15:13:29.033 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-04-07 15:13:29.038 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-04-07 15:13:29.038 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-04-07 15:13:29.039 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-04-07 15:13:29.100 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-04-07 15:13:29.100 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-04-07 15:13:29.100 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-04-07 15:14:26.275 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-04-07 15:44:31.746 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
I know the common response is to factory reset it and restore a backup. Unfortunately, the last backup was from last year.
Is there any way to create a backup from console and download it to my computer via serial console? Or is there any way to figure out what the issue and fix it?
I found the commands to remove the nut addon and now when I reboot it, it shows all green on the supervisor logs and if I run ha os update, it comes back as the latest version and that it is booted to slot B: running 15.1. Everything looks like it is working fine, but still no web, ssh, or app can connect it other than using serial console.
