And how it is now. Unfortunately the response was very weak. But is it better now, a little.
When looking at Silicon labs documents, it is surely configurable to use external antenna. But how it can be done in HA is beyond my skills.
[1/3] (iām only allowed 2 links per post).
Disclaimer: iām not an expert in zigbee, and all the following information is the result of half-day spent on digging in silabs and NabuCasa github resources.
So, thatās right, J9 is indeed RF2G4_IO2, designed for the external antenna.
(official source - https://www.silabs.com/documents/public/data-sheets/mgm210p-datasheet.pdf, p33)
But enabling it is really not well documented to say the least.
Some information on silabs forums and KBA is quite outdated, and no longer applicable for the current SDK.
Eg. Silicon Labs Community
Antenna stub plugin is no longer there, all that has changed in a past few years.
[2/3]
However, it seems that the right place to configure it now is config/sl_rail_util_rf_path_config.h
Example:
And SL_RAIL_UTIL_RF_PATH_INT_RF_PATH_MODE
is in fact being used for antennaConfig.defaultPath
and RAIL_ConfigAntenna
[3/3]
Iāve manually followed the automated build process used in GitHub - NabuCasa/silabs-firmware-builder: Silicon Labs firmware builder (github actions) and indeed ANTENNA_0 is being configured (in config/sl_rail_util_rf_path_config.h) and used for MGM210PA32JIA
I managed to build the firmware, changing it to ANTENNA_1, but canāt try it out - my soldering skills are likely much worse than in software and iām not immediately having any u.fl handy
By the way, has the J9 been connected to the ground before the soldering?
Anyway, having h/w modification already performed, i would definitely give it a try to updated firmware.
Essentially, I followed steps described in those 3 files:
I could also share the binary, but wouldnāt recommend to trust it and build it yourself instead.
Please let me know if you need any detailed instructions.
It is not totally grounded. Iām pretty sure, that there is some inductor/feeding thing to ground.
That software part is hard to me. Iād like to test, but i need more detailed instructions. Very noob.
Iāve forked the repo to at least make the build straightforward, you can see the diff here:
If you have any github login , you should be able to download the artifact (zip including gbl file) from the action page, direct link:
https://github.com/mrozentsvayg/silabs-firmware-builder/actions/runs/8025422656/artifacts/1271052054
Based on emberznet 7.4.0.0 (4.4.0 gecko sdk)
Very interested to see if that works, please report back or let me know if thereās anything else to unblock it.
Whatās you current firmware by the way? Iāve upgraded from default 6.x to 7.3.1.0 (silabs_flasher add-on) couple days ago and it seems to be working a little better. A few end devices - couple of third reality water leak sensors and hue motion sensor kept going unavailable, holding better so far. Too soon to tell though.
Ouch, there is now a small problem. Iām very old electrician from analog-era. I have no idea, what i should do? I can copy file, if i know to where, or edit file but how i locate correct one? Very noob, as i said. Yep, firmware version. Perhaps it can be found somewhereā¦
No worries.
The current version could be found at the coordinatorās device page.
In the Settings -> Devices & Services -> Zigbee Home Automation
click on devices list and find the device. It should be named āSilicon Labs EZSPā.
In the meantime let me (try to) find the easiest way to flash the firmware ā¦
Hereās a doc:
Elaborated steps:
pip install universal-silabs-flasher
scp ncp-uart-hw.gbl [email protected]:
$ universal-silabs-flasher --device /ttyAMA1 flash --allow-cross-flashing --firmware ncp-uart-hw.gbl
I canāt find any for Silicon Labs. Only zigbee coordinator is listed. Its version is 6.10.3.0 build 297. I canāt go further from that wiev.
Wondering if you recently restarted the home assistant or just installed the 2024.3 update?
It also showed as āZigbee Coordinatorā to me right after the update, then after several minutes it popped up back as āSilicon Labs EZSPā in the list.
Itās not an issue anyway, you could follow the steps to update the firmware as described in the post above.
There was a core update few hours ago. After that i didnāt do separate reboot.
Have to focus to this tomorrow, now i have too many beers in my headā¦
Are one of these suitable for that purpose?
And this is also available in official add-onsā¦
That āSilicon Labs EZSPā wonāt show. It is only mentioned properties of zigbee coordinator, but no version.
You need the āAdvanced SSH & Web Terminalā.
It would allow you to use python packages (pip) and provides access to the usb port (once the protection mode is disabled)
This is a good plugin, but it would upgrade the firmware to the only 7.3.1.0
it doesnāt support flashing custom files, only those inside the add-on
Could you please take a screenshot of the device page?
Ok. I will need the usb-port also? Transferring files or ? Sorry my stupidity, software things are never been my thing. Only programming language what i have learned, is Microchip assembler. Perhaps, when it is like turning switchesā¦
Forwarding slowly. I registered into github and now i have that file.
Great, now just follow the steps in the post above:
and let me know if thereās anything confusing
