Home Assistant Yellow does not boot
Hi all,
I have a Home Assistant Yellow that has worked without issue since release. The other day it just stopped working. I thought that this may have been an update that prevented it from booting.
I hadn’t tried the console, but went straight ahead and re-flashed a USB drive and did a reinstall. Everything seemed to install fine, lights indicated so. But I was unable to access the Home Assistant via the IP address, however I could ping the IP address fine.
Now I seem to have a bigger issue as the system is totally powered off. It’s a PoE system, so on inserting the network cable I get the green and red LEDs for about 10 seconds before they turn off completely.
The memory chip + CPU are correctly seated, there seems to be no issue internally (that I can see). I’d appreciate any advice on troubleshooting. As is not surprising, I can’t access the Home Assistant by the Console now either.
Thanks in advance.
Try a power supply brick instead of PoE
OK, will do :slight_smile:
Hey all,
After trying a dedicated power supply instead of PoE. My Home Assistant Yellow still itn’s booting.
Are there any other recommendations to troubleshoot the hardware?
