Asking in case someone is aware or find something similar. I’m on the search of a Home Assistant Yellow enclosure, not the default one, that could potentially hold a space or ventilation spaces on the upper part so a heatsink + a fan, can fit. Examples:
The HA Yellow enclosure has no ventilation holes.
The Yellow IO board has no EMC2301 (PWM) controller and no fan connector.
So not much active or passive cooling. Please someone tell me I am wrong.
My plan is to solder a fan to +12v and print a 3D enclosure to accommodate it.
Anyone have a better idea? Cuz, this is disappointing.
Please add an active cooling solution to the generation after HA Yellow.
In the meantime… will be looking for a different RPi CM5 IO board with NVMe.
