I have attempted to install using these instructions Home assistant
But on doing do I get no boot up or any yellow lights to indicate the flash is installing onto it.
I’m just getting a red and green light no flashing at all or anything to indicate an error. I have a feeling its a faulty board and needs to be returned. Has anyone any clue
Same issue here. I purchased two devices, one POE and one with power brick for my daughters house. The POE device loaded perfectly, the power brick version failed with the red and green lights flashing sporadically but refused to load from USB. I and going to try swapping the CM4 module I loaded on the POE device over to the non POE device and see if it boots into HA OS successfully. If I can load the swapped CM4 module on the POE device that rules out a faulty CM4 module and ties this issue to the non POE model… I’ll post my findings later this coming week when I get a chance to test further.
Just curious if the above posts that had failures were using the POE or non POE kits.
