Home Assistant Yellow Kit Edition - Blinking yellow takes forever (HELP)
Hi, I just bought Home Assistant Yellow Kit with Power Supply. It comes with CM4 - 8G RAM, 32G eMMc. I followed the given instructions to fixed the hard components, flashed the image of HA OS Installer for Yellow into a USB stick, plugged it in together with the network cable and turned on the power. Red LED was on persistently while the green LED flashed every 4 secs and yellow flashed every 2 secs. 8 hours later and red is still on, yellow is still flashing. Can anyone advise how I should proceed? Thank you.
Mark
https://yellow.home-assistant.io/guides/yellow-leds/
Thanks for the info. From the yellow blinking pattern, it should be down loading and installing. But it can’t be taking more than 6 hours doing so. Anyone faced the same problem?
I managed to resolved it. The router port I used is faulty. From the blinking yellow light, it seems like things are moving but actually not so. So in case someone else encounters the same, plug your ethernet cable to another port and try again
