Good Day
I have an issue installation home assistant n Yellow.
the components
- Module 5
- m.2 NM620 Lexar
then I have Writing the installer onto the M.2
Please see the screenshot of the error .
Good Day
the components
An internet connection is needed.
there is internet connection
The error message indicates that Home Assistant cannot connect to the internet; therefore, if you have an internet connection, it is not configured properly to allow HA to access what it needs to complete the configuration.
Check your network settings on your router and elsewhere to ensure the Yellow can access the internet properly.
Thanks, problem solved
Good you solved it yourself!
Please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
Thanks for giving back to the community!
