Home Assistant Yellow not Reboot throw UI
I have this problem on Home Assistant Yellow:
when I reboot the device it system shutdowns but not start (led red and green on). I have to unplug and plug power for it works correctly.
The restart of only HA it works.
HA Core logs report:
INFO: Home Assistant Core finish process exit code 0
INFO: Home Assistant Core service shutdown
I tried “ha core check”, all OK.
Hardware:
  • Home Assistant Yellow rev 1.2 with standard power supply.
  • NVME Corsair P2 256GB
Software:
  • Supervisor 2022.12.1
  • Operating System 9.4
  • Frontend 20221231.1
Thank all for your time.
I add boot from console:
PCIe BRCM: link up, 5.0 Gbps x1 (SSC)
starting USB...
No working controllers found
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2922 bytes read in 13 ms (218.8 KiB/s)
## Executing script at 02400000
loading env...
MMC read: dev # 0, block # 1214464, count 32 ... 32 blocks read: OK
gpio: pin GPIO27 (gpio 27) value is 1
gpio: pin GPIO26 (gpio 26) value is 1
Trying to boot slot B, 2 attempts remaining. Loading kernel ...
23611904 bytes read in 1359 ms (16.6 MiB/s)
storing env...
MMC write: dev # 0, block # 1214464, count 32 ... 32 blocks written: OK
Starting kernel
Moving Image from 0x80000 to 0x200000, end=1990000
## Flattened Device Tree blob at 2eff2400
   Booting using the fdt blob at 0x2eff2400
   Using Device Tree in place at 000000002eff2400, end 000000002f002fb6
Starting kernel ...
I have the same problem. After a reboot the system shutdowns but doesn’t start.
I’ve got a similar issue. Normal HA restarts are fine, but anything involving a system reboot often requires me to unplug power and plug back in again.
