I have a HA yellow PoE with an SSD (Seagate ZP500GM3A023), and it exhibits groups of errors w/ reboots like those below frequently, up to several times an hour. I’ve tried removing the CM4 and SSD and re-seating them, which hasn’t helped. It should have plenty of PoE power available: it’s currently drawing 2.7W, and only 24W of the 40W budget is in use on that switch (Unifi Flex powered by the 60W power supply from the Flex Utility). Other PoE devices on that switch, including a 10W device, work fine. Any ideas on what to try to address this?
Edit: I tried both jumper positions for the PoE power class, with no difference.
Feb 06 13:42:12 hass-house kernel: pcieport 0000:00:00.0: AER: Multiple Corrected error received: 0000:00:00.0
Feb 06 13:42:12 hass-house kernel: pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Feb 06 13:42:12 hass-house kernel: pcieport 0000:00:00.0: device [14e4:2711] error status/mask=00001100/00002000
Feb 06 13:42:12 hass-house kernel: pcieport 0000:00:00.0: [ 8] Rollover
Feb 06 13:42:12 hass-house kernel: pcieport 0000:00:00.0: [12] Timeout
Feb 06 13:42:12 hass-house kernel: nvme 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Feb 06 13:42:12 hass-house kernel: nvme 0000:01:00.0: device [1bb1:5018] error status/mask=00001000/00006000
Feb 06 13:42:12 hass-house kernel: nvme 0000:01:00.0: [12] Timeout
Feb 06 13:45:11 hass-house kernel: pcieport 0000:00:00.0: AER: Multiple Corrected error received: 0000:00:00.0
Feb 06 13:45:11 hass-house kernel: pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Feb 06 13:45:11 hass-house kernel: pcieport 0000:00:00.0: device [14e4:2711] error status/mask=00001100/00002000
Feb 06 13:45:11 hass-house kernel: pcieport 0000:00:00.0: [ 8] Rollover
Feb 06 13:45:11 hass-house kernel: pcieport 0000:00:00.0: [12] Timeout
Feb 06 13:45:11 hass-house kernel: nvme 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Feb 06 13:45:11 hass-house kernel: nvme 0000:01:00.0: device [1bb1:5018] error status/mask=00001000/00006000
Feb 06 13:45:11 hass-house kernel: nvme 0000:01:00.0: [12] Timeout
Feb 06 13:46:12 hass-house kernel: pcieport 0000:00:00.0: AER: Corrected error received: 0000:00:00.0
Feb 06 13:46:12 hass-house kernel: pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Feb 06 13:46:12 hass-house kernel: pcieport 0000:00:00.0: device [14e4:2711] error status/mask=00001000/00002000
Feb 06 13:46:12 hass-house kernel: pcieport 0000:00:00.0: [12] Timeout
Feb 06 13:46:46 hass-house kernel: pcieport 0000:00:00.0: AER: Multiple Corrected error received: 0000:00:00.0
Feb 06 13:46:46 hass-house kernel: pcieport 0000:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Feb 06 13:46:46 hass-house kernel: pcieport 0000:00:00.0: device [14e4:2711] error status/mask=00001100/00002000
Feb 06 13:46:46 hass-house kernel: pcieport 0000:00:00.0: [ 8] Rollover
Feb 06 13:46:46 hass-house kernel: pcieport 0000:00:00.0: [12] Timeout
-- Boot 57df44e29abf46ae87fb2548f40faf77 --
Apr 04 10:55:23 homeassistant kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd083]
Apr 04 10:55:23 homeassistant kernel: Linux version 6.1.63-haos-raspi (builder@13ed6d6d8021) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot -g2d89a0f9) 11.4.0, GNU ld (GNU Binutils) 2
.38) #1 SMP PREEMPT Tue Jan 9 10:42:51 UTC 2024
