I just got my Yellow yesterday and I am unable to flash the eMMC storage on my CM4 via USB. I had to buy my CM4 as part of a Seeed router, so I suspect it already had an OS installed or boot order modified to use the SD card on the Seeed router board. When I would plug in the USB drive with the installer and power on the Yellow the yellow light would not start blinking. I followed the instructions for how to reinstall the OS (Home Assistant Yellow Guide) using method 1 by holding the red and blue buttons. I was able to get the yellow light to start the “heart beat” flash but it would never finish, I left it all night. So I start reading method 2 and it says to jumper the JP2 (USB-C Rcvry) but my board doesn’t have jumpers it has a button. It also says to leave it jumpered till the flash utility is done, then remove the jumper. I am I supposed to hold the button till it is done? How long does the flash take? Going to be doing this using windows 10.
With CM4s being in short supply I suspect there will be many being pulled out of other systems instead of buying just the CM4 module new. If the home assistant team put together an install guide using a CM4 module that has already been setup to be used with some other systems and put it in the setup guide that would be great.
