Home Assistant Yellow USB ports
Hello, suddenly my USB A ports don’t seem to be working.
I have the Zooz 700 stick, I can see it on my Windows PC, I was able to update the firmware with the Windows PC.
It has been working, with the occasional need to reboot, since I think middle of 2022 maybe or thereabouts.
I normally run over POE, but also switched over to a 12v 2a power supply as test and no difference.
I don’t have another zwave stick to test at this time, but as it is readable on the Windows PC, etc.
Zwave JS and JS UI (installed at different times) both have the same error:
2024-03-20 14:17:38.266 INFO APP: GET /api/store 304 870.432 ms - -
2024-03-20T18:17:38.538Z CNTRLR   querying Serial API capabilities...
2024-03-20T18:17:39.546Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2024-03-20T18:17:40.652Z CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                  n 1100 ms.
2024-03-20T18:17:42.761Z DRIVER   Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
                                  from the controller (ZW0200)
                                      at Driver.sendMessage (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts
                                  :5256:23)
                                      at ZWaveController.identify (/opt/node_modules/zwave-js/src/lib/controller
                                  /Controller.ts:897:37)
                                      at Driver.initializeControllerAndNodes (/opt/node_modules/zwave-js/src/lib
                                  /driver/Driver.ts:1432:26)
                                      at Immediate.<anonymous> (/opt/node_modules/zwave-js/src/lib/driver/Driver
                                  .ts:1226:16)
2024-03-20 14:17:42.763 INFO Z-WAVE: Restarting client in 15 seconds, retry 19
2024-03-20 14:17:47.562 INFO APP: GET /health/zwave 301 1.215 ms - 191
2024-03-20 14:17:57.769 INFO GATEWAY: Driver is CLOSED
2024-03-20 14:17:57.770 INFO Z-WAVE-SERVER: Server closed
2024-03-20 14:17:57.772 INFO Z-WAVE: Client closed
2024-03-20 14:17:57.774 INFO GATEWAY: Driver is CLOSED
2024-03-20 14:17:57.781 INFO Z-WAVE: Connecting to /dev/ttyAMA0
2024-03-20 14:17:57.783 INFO Z-WAVE: Setting user callbacks
2024-03-20T18:17:57.787Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
2024-03-20T18:17:57.789Z DRIVER   version 12.4.4
2024-03-20T18:17:58.800Z CONFIG   version 12.4.4
2024-03-20T18:18:00.036Z CNTRLR   querying Serial API capabilities...
2024-03-20T18:18:01.051Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2024-03-20T18:18:02.157Z CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                  n 1100 ms.
2024-03-20T18:18:04.268Z DRIVER   Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
                                  :5256:23)
                                  .ts:1226:16)
2024-03-20 14:18:04.271 INFO Z-WAVE: Restarting client in 15 seconds, retry 20
2024-03-20 14:18:17.679 INFO APP: GET /health/zwave 301 2.594 ms - 191
2024-03-20 14:18:19.273 INFO GATEWAY: Driver is CLOSED
2024-03-20 14:18:19.275 INFO Z-WAVE-SERVER: Server closed
2024-03-20 14:18:19.278 INFO Z-WAVE: Client closed
2024-03-20 14:18:19.279 INFO GATEWAY: Driver is CLOSED
2024-03-20 14:18:19.286 INFO Z-WAVE: Connecting to /dev/ttyAMA0
2024-03-20 14:18:19.288 INFO Z-WAVE: Setting user callbacks
2024-03-20T18:18:19.290Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
2024-03-20T18:18:19.291Z DRIVER   version 12.4.4
2024-03-20T18:18:19.292Z DRIVER
2024-03-20T18:18:20.304Z CONFIG   version 12.4.4
2024-03-20T18:18:21.456Z CNTRLR   querying Serial API capabilities...
2024-03-20T18:18:22.467Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2024-03-20T18:18:23.573Z CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                  n 1100 ms.
2024-03-20T18:18:25.681Z DRIVER   Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
                                  :5256:23)
                                  .ts:1226:16)
2024-03-20 14:18:25.685 INFO Z-WAVE: Restarting client in 15 seconds, retry 21
2024-03-20 14:18:40.686 INFO GATEWAY: Driver is CLOSED
2024-03-20 14:18:40.690 INFO Z-WAVE-SERVER: Server closed
2024-03-20 14:18:40.693 INFO Z-WAVE: Client closed
2024-03-20 14:18:40.696 INFO GATEWAY: Driver is CLOSED
2024-03-20 14:18:40.703 INFO Z-WAVE: Connecting to /dev/ttyAMA0
2024-03-20 14:18:40.704 INFO Z-WAVE: Setting user callbacks
2024-03-20T18:18:40.707Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
2024-03-20T18:18:40.708Z DRIVER   version 12.4.4
2024-03-20T18:18:41.720Z CONFIG   version 12.4.4
2024-03-20T18:18:42.955Z CNTRLR   querying Serial API capabilities...
2024-03-20T18:18:43.973Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2024-03-20T18:18:45.080Z CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                  n 1100 ms.
2024-03-20T18:18:47.191Z DRIVER   Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
                                  :5256:23)
                                  .ts:1226:16)
2024-03-20 14:18:47.193 INFO Z-WAVE: Restarting client in 15 seconds, retry 22
have tried the different ports here:
i also ran
ha hardware info
in terminal, what should i look for, please?
