I’m running Sonoff Smart Plugs; S31 to be clear on WiFi (no bluetooth or Zigbee), others are running switches, thermostats, so yes it will run out of the box. Now the question how to connect with it, since it has the icons IFTTT and Zigbee. Does your HA have zigbee up and running? If so then it came with the radio module (IIRC bluetooth, WiFi, Zigbee). It should be seen/discovered when powered up if it is within reach of the radio.
You may have some radio interference because the WiFi channels and the Zigbee channels over lap each other.
Then there is the integration piece. What do you plan to use? eWelink HA, Sonoff by AlexxIT, MQTT broker?
Hopeful others who have it will chime in on their experience.
The first main issue is the radio communication with these IoT devices. By that I mean a good constant communications without dropouts or disconnects.
