Home assistant yellow won't start after moving datadisk
Recently i received by Home Assistant Yellow. Since i had a CM4 module with a hybrid data solution by using an external USB drive i decided to simply move the CM4 directly to the yellow and inserting the USB drive without redeploying home assistant. This worked almost perfectly. Now i received my NVMe SSD and installed it as described in the yellow guide. Afterwards i booted HA and pressed move datadisk. After 2 hours of HA was not starting and i knew something had went wrong. Ever since i have not been able to boot the device. I have tried installing the CM4 back into the PiTray mini to watch the error on a screen. The following message appeared before the rpi went into black screen:
My biggest problem right now is that i can’t seem to even be able to re-install home assistant. I have tried inserting an USB drive including a fresh install of HA using the rpi-imager tool but the device does not seem to boot from that USB. Any ideas?
Followed this guide to do a full recovery using option 2 since option 1 did not work.
Option 2 worked for me.
