Home Assistant Yellow + ZBT-1
Hi, I’ve got HA Yellow that I use to operate Zigbee network. I’d also like to experiment with Thread and since running Zigbee & Thread from Yellow’s built in chip is not recommended, I’m wondering if purchasing and using ZBT-1 for Thread protocol is supported?
Hello Tomas Bezdek,
Welcome to the HA forum.
Yes you can add a ZBT-1 or other suitable dongle. Be sure to use a minimum 1 meter extension cable.
I suggest you don’t try to set-up 2 zigbee networks, because that can be confusing, but if you use one as a border router you will be fine.
