Yes, it is working now without ssl. Thanks!
I updated to Supervisor version 2020.12.6 and to Operating System
Home Assistant OS 5.8 and network viewer stopped working. I tried restarting and rebuilding but nothing worked. I uninstalled and now it will not install. I get this error.
The command '/bin/ash -o pipefail -c apk add --no-cache python3 py3-pip musl && apk add --no-cache --virtual .build-deps build-base python3-dev git libffi-dev openssl-dev && git clone --depth=1 https://github.com/elad-bar/ha-zwave-network.git && cd ha-zwave-network && pip install --no-cache-dir requests asyncws aiofiles flask pyopenssl && mkdir -p /web && find . -print | sed '/.git|Dockerfile/d' | cpio -pvdm / && apk del .build-deps && cd .. && rm -rf /usr/src/ha-zwave-network.git && mkdir /debug' returned a non-zero code: 39.
Help please.
I will fix it at the weekend
Great! Thank you.
Itās still not working.
Iām running home assistant with OpenZWave (beta) and network viewer all of them in docker containers but Iām not able to get a Z-wave graphic, both the graphic and the nodes.json are empty.
This is my log
INFO:Managers.configuration_manager:Configuration is valid, data: {'home_assistant_url': 'http://192.168.0.70:8123/', 'home_assistant_token': 'eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI3MDIwYThjGQ0M2UxOTI5MmQ1NGU0NDM2YWExYiIsImlhdCI6MTYwMzE44gTyODQ2OCwiZXhwIjoxOTE4NDg4NDY4fQ.q3SG1VUeWNpNGNvSUYRr6QBrjNgxbeTgVRAAYoKIG9m0', 'ssl_key': '', 'ssl_certificate': '', 'is_debug': True, 'is_local': False, 'server_port': 6123, 'home_assistant_web_socket_url': 'ws://192.168.0.70:8123/', 'is_ssl': False, 'ssl_context': None}
* Serving Flask app "webserver" (lazy loading)
DEBUG:asyncio:Using selector: EpollSelector
* Environment: production
WARNING: This is a development server. Do not use it in a production deployment.
Use a production WSGI server instead.
INFO:Managers.data_manager:Connecting to ws://192.168.0.70:8123/
* Debug mode: on
ERROR:Managers.data_manager:Failed to connect due to error: 'NoneType' object has no attribute 'encode' [LN: 96]
INFO:werkzeug: * Running on http://0.0.0.0:6123/ (Press CTRL+C to quit)
INFO:werkzeug: * Restarting with stat
WARNING:werkzeug: * Debugger is active!
INFO:werkzeug: * Debugger PIN: 196-535-277
Can anybody help me?
AFAIK this doesnāt work with the openzwave beta (yet).
According to the description in GitHub it does
I was using the app with OpenZwave beta until it stopped when i upgraded Supervisor version 2020.12.6 and to Operating System Home Assistant OS 5.8.
Does this tool adjust the link line colors based on the link quality if the data is available via ozw
FYI, this fails to build under the latest version of supervisor and HA when using @sjthespianās add-on.
fetch http://dl-cdn.alpinelinux.org/alpine/v3.12/main/aarch64/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/v3.12/community/aarch64/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/edge/main/aarch64/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/edge/community/aarch64/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/edge/testing/aarch64/APKINDEX.tar.gz
ERROR: unsatisfiable constraints:
libcrypto1.1-1.1.1g-r0:
breaks: openssl-dev-1.1.1i-r0[libcrypto1.1=1.1.1i-r0]
satisfies: world[libcrypto1.1=1.1.1g-r0]
ca-certificates-20191127-r4[so:libcrypto.so.1.1]
python3-3.8.5-r0[so:libcrypto.so.1.1]
libcurl-7.69.1-r0[so:libcrypto.so.1.1]
apk-tools-2.10.5-r1[so:libcrypto.so.1.1]
libssl1.1-1.1.1g-r0[so:libcrypto.so.1.1]
libtls-standalone-2.9.1-r1[so:libcrypto.so.1.1]
libssl1.1-1.1.1g-r0:
breaks: openssl-dev-1.1.1i-r0[libssl1.1=1.1.1i-r0]
satisfies: world[libssl1.1=1.1.1g-r0]
python3-3.8.5-r0[so:libssl.so.1.1]
libcurl-7.69.1-r0[so:libssl.so.1.1]
apk-tools-2.10.5-r1[so:libssl.so.1.1]
libtls-standalone-2.9.1-r1[so:libssl.so.1.1]
Removing intermediate container 6a18858c74dd
I will check it in the weekend, I have the same issueā¦
checked it once again, the OZWDaemon failed and thatās caused the service āfailureā, so I donāt have a real issue working with OZW,
Are you using the docker or addon?
thanks
Hi Bar,
Iām not sure if your question is for me but Iām using OZWDaemon and Home Assistant core both running in docker containers
I meant for the zwave network viewer, is it the docker or addon of HA (how did you installed the viewer)?
Iāve the viewer also installed in docker
according to the log above, it seems that you have connection issue with HA,
It can cause due to wrong URL or wrong token,
please make sure the url is accesible (from the container), if it is accesible, please generate a new long lived access token and update the environment variable.
please let me know if it worked for you
thanks
This is the error I get on installation:
## Failed to install addon
and this:
(3/33) Installing libffi (3.3-r2)
(4/33) Installing gdbm (1.13-r1)
(5/33) Installing xz-libs (5.2.5-r0)
(6/33) Installing sqlite-libs (3.32.1-r0)
(7/33) Installing python3 (3.8.5-r0)
(8/33) Installing py3-appdirs (1.4.4-r1)
(9/33) Installing py3-ordered-set (4.0.1-r0)
(10/33) Installing py3-parsing (2.4.7-r0)
(11/33) Installing py3-six (1.15.0-r0)
(12/33) Installing py3-packaging (20.4-r0)
(13/33) Installing py3-setuptools (47.0.0-r0)
(14/33) Installing py3-chardet (3.0.4-r4)
(15/33) Installing py3-idna (2.9-r0)
(16/33) Installing py3-certifi (2020.4.5.1-r0)
(17/33) Installing py3-urllib3 (1.25.9-r0)
(18/33) Installing py3-requests (2.23.0-r0)
(19/33) Installing py3-msgpack (1.0.0-r0)
(20/33) Installing py3-lockfile (0.12.2-r3)
(21/33) Installing py3-cachecontrol (0.12.6-r0)
(22/33) Installing py3-colorama (0.4.3-r0)
(23/33) Installing py3-distlib (0.3.0-r0)
(24/33) Installing py3-distro (1.5.0-r1)
(25/33) Installing py3-webencodings (0.5.1-r3)
(26/33) Installing py3-html5lib (1.0.1-r4)
(27/33) Installing py3-pytoml (0.1.21-r0)
(28/33) Installing py3-pep517 (0.8.2-r0)
(29/33) Installing py3-progress (1.5-r0)
(30/33) Installing py3-toml (0.10.1-r0)
(31/33) Installing py3-retrying (1.3.3-r0)
(32/33) Installing py3-contextlib2 (0.6.0-r0)
(33/33) Installing py3-pip (20.1.1-r0)
Executing busybox-1.31.1-r16.trigger
OK: 72 MiB in 58 packages
Removing intermediate container 1b1425fb1809
Hi Bar,
I tried generating a new token but I still get the error
I build my containers with docker compose and my HA container is in host mode so I tried to ping my host IP address from inside the viewer container with the following command and I get a response
docker exec -ti ha-zwave-network ping 192.168.0.70
Do you have any other ideas?
since I didnāt create the addon, I cannot fix it,
It requires the addon ownerās attention to align packages
