just to be sure, you are not using HTTPs, right?
in addition, can you try this:
docker exec -ti ha-zwave-network wget http://192.168.0.70:8123
what is the response?
Hi Bar,
No, i do not use a SSL certificate. I tried the command you gave me and this is the result
Connecting to 192.168.0.70:8123 (192.168.0.70:8123)
saving to 'index.html'
index.html 100% |********************************| 3327 0:00:00 ETA
'index.html' saved
Sorry, Iāve been buried at work lately and havenāt been watching the forums. This is odd, for some reason the versions of openssl-dev and libssl donāt align. Itās getting 1.1.1g of the dev libraries but only 1.1.1g of libssl.
Supposedly the fix is to switch to libressl-dev, but when I do that it builds but doesāt work over an SSL connection. Iām going to do some more digging and see if I can get to the bottom of the incompatible versions. Worst case, Iāll see if I can pin both packages to the same version to fix this.
A new version of the add-on is up that should fix the build issue. It should automatically show up as an upgrade to version 0.4.
Thanks for the fix. It is working well now.
Happy New Year
Any clue about the issue with the docker container I mentioned above? I pulled the latest image but still having the same issue
I am still unable to get this working on a pi4 hassos 64bit. Iām installing the 0.4 version and have tried removing and re-adding the repo. This is what I see in the supervisor logs:. It sits at starting build.
21-01-03 13:30:11 INFO (MainThread) [supervisor.store] Loading add-ons from store: 72 all - 0 new - 1 remove
21-01-03 13:30:19 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/sjthespian/addon-zwave-network-viewer repository
21-01-03 13:30:20 INFO (MainThread) [supervisor.store] Loading add-ons from store: 73 all - 1 new - 0 remove
21-01-03 13:30:29 INFO (SyncWorker_1) [supervisor.docker.addon] Starting build for 76287f4b/aarch64-addon-zwavenetworkviewer:0.4
That output is normal, but it should eventually come back with a message saying that the image was built. This is what I see on my RPi4:
21-01-01 03:45:04 INFO (SyncWorker_0) [supervisor.docker.addon] Starting build for 76287f4b/armv7-addon-zwavenetworkviewer:0.4
21-01-01 03:49:01 INFO (SyncWorker_0) [supervisor.docker.addon] Build 76287f4b/armv7-addon-zwavenetworkviewer:0.4 done
21-01-01 03:49:01 INFO (MainThread) [supervisor.addons] Add-on '76287f4b_zwavenetworkviewer' successfully installed
21-01-01 03:50:36 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on 76287f4b/armv7-addon-zwavenetworkviewer with version 0.4
Yeah Iām not sure whatās happening but it fails to do anything after days of leaving it sit. Itās weird. Havenāt had much time to dig in.
If you have ssh enabled on your HA server, you can try building the container yourself to see if itās something specific to your system. You should be able to ssh in, cd to /addons, git clone the repo there, and then run: docker build .
in the zwave-network-viewer directory. You might not have /addons by default, I think I may have had to disable protection mode in the SSH & Web Terminal addon to get that to show up.
So this was actually my fault. Iām running opnsense with suricata and it was dropping the traffic. Once excluded, it built immediately.
Thanks for this. Got it working on my new configuration. Any chance you can add support for Docker secrets so I donāt have to add the token in the docker compose file?
