I have home assistant running on balena on a rpi3. I have added containers for mqtt and zigbe2mqtt integrations. Home assistant has discovered and integrated MQTT successfully, but I am having difficulty with integrating zigbee2mqtt.
First observation: When it comes to the integration it looks as if HA has added z2m as a zha component, if that make sense – new to all this.
Here is the error:
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:172
First occurred: 12:06:45 (3 occurrences)
Last logged: 12:38:56
Error setting up entry Sonoff Zigbee 3.0 USB Dongle Plus - Sonoff Zigbee 3.0 USB Dongle Plus for zha
Error setting up entry Sonoff Zigbee 3.0 USB Dongle Plus for zha
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 998, in request
response = await response_future
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 365, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 112, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 185, in async_initialize
raise exc
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 172, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 144, in new
await app.startup(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 124, in startup
await self.connect()
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py", line 106, in connect
await znp.connect()
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 710, in connect
self.version = await self.detect_zstack_version()
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 85, in detect_zstack_version
await self.nvram.read(
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/nvram.py", line 315, in read
length_rsp = await self.znp.request(
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 994, in request
async with async_timeout.timeout(
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 129, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 212, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
