Hi i am attempting to install hasbian image on my raspberry pi 3 this is not the first time i am doing this but is the first that HA crashes after install and i have no idee what to do with it.
I changed the sd card, i update i deed not update and still will crash.
there is my log. just after fresh install and first reboot:
‘The following errors have been logged this session:17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.frontend. Make sure all dependencies are installed Traceback (most recent call last): File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/loader.py”, line 141, in get_component module = importlib.import_module(path) File “/usr/lib/python3.4/importlib/init.py”, line 109, in import_module return _bootstrap._gcd_import(name[level:], package, level) File “”, line 2254, in _gcd_import File “”, line 2237, in _find_and_load File “”, line 2226, in _find_and_load_unlocked File “”, line 1200, in _load_unlocked File “”, line 1129, in _exec File “”, line 1471, in exec_module File “”, line 321, in _call_with_frames_removed File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/frontend/init.py”, line 12, in from homeassistant.components import api, group File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/api.py”, line 26, in from homeassistant.helpers.state import AsyncTrackStates File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/state.py”, line 8, in from homeassistant.components.media_player import ( File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/media_player/init.py”, line 24, in from homeassistant.components.http import HomeAssistantView, KEY_AUTHENTICATED File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/init.py”, line 34, in from .static import FILE_SENDER, CACHING_FILE_SENDER, staticresource_middleware File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/static.py”, line 6, in from aiohttp.file_sender import FileSender ImportError: No module named ‘aiohttp.file_sender’ 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Unable to find component frontend 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Component not found. 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.logbook. Make sure all dependencies are installed Traceback (most recent call last): File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/loader.py”, line 141, in get_component module = importlib.import_module(path) File “/usr/lib/python3.4/importlib/init.py”, line 109, in import_module return _bootstrap._gcd_import(name[level:], package, level) File “”, line 2254, in _gcd_import File “”, line 2237, in _find_and_load File “”, line 2226, in _find_and_load_unlocked File “”, line 1200, in _load_unlocked File “”, line 1129, in _exec File “”, line 1471, in exec_module File “”, line 321, in _call_with_frames_removed File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/logbook.py”, line 18, in from homeassistant.components.frontend import register_built_in_panel File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/frontend/init.py”, line 12, in from homeassistant.components import api, group File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/api.py”, line 26, in from homeassistant.helpers.state import AsyncTrackStates File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/state.py”, line 8, in from homeassistant.components.media_player import ( File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/media_player/init.py”, line 24, in from homeassistant.components.http import HomeAssistantView, KEY_AUTHENTICATED File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/init.py”, line 34, in from .static import FILE_SENDER, CACHING_FILE_SENDER, staticresource_middleware File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/static.py”, line 6, in from aiohttp.file_sender import FileSender ImportError: No module named ‘aiohttp.file_sender’ 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Unable to find component logbook 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Component not found. 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.config. Make sure all dependencies are installed Traceback (most recent call last): File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/loader.py”, line 141, in get_component module = importlib.import_module(path) File “/usr/lib/python3.4/importlib/init.py”, line 109, in import_module return _bootstrap._gcd_import(name[level:], package, level) File “”, line 2254, in _gcd_import File “”, line 2237, in _find_and_load File “”, line 2226, in _find_and_load_unlocked File “”, line 1200, in _load_unlocked File “”, line 1129, in _exec File “”, line 1471, in exec_module File “”, line 321, in _call_with_frames_removed File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/config/init.py”, line 11, in from homeassistant.components.frontend import register_built_in_panel File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/frontend/init.py”, line 12, in from homeassistant.components import api, group File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/api.py”, line 26, in from homeassistant.helpers.state import AsyncTrackStates File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/state.py”, line 8, in from homeassistant.components.media_player import ( File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/media_player/init.py”, line 24, in from homeassistant.components.http import HomeAssistantView, KEY_AUTHENTICATED File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/init.py”, line 34, in from .static import FILE_SENDER, CACHING_FILE_SENDER, staticresource_middleware File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/static.py”, line 6, in from aiohttp.file_sender import FileSender ImportError: No module named ‘aiohttp.file_sender’ 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Unable to find component config 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.setup] Setup failed for config: Component not found. 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.history. Make sure all dependencies are installed Traceback (most recent call last): File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/loader.py”, line 141, in get_component module = importlib.import_module(path) File “/usr/lib/python3.4/importlib/init.py”, line 109, in import_module return _bootstrap._gcd_import(name[level:], package, level) File “”, line 2254, in _gcd_import File “”, line 2237, in _find_and_load File “”, line 2226, in _find_and_load_unlocked File “”, line 1200, in _load_unlocked File “”, line 1129, in _exec File “”, line 1471, in exec_module File “”, line 321, in _call_with_frames_removed File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/history.py”, line 20, in from homeassistant.components.frontend import register_built_in_panel File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/frontend/init.py”, line 12, in from homeassistant.components import api, group File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/api.py”, line 26, in from homeassistant.helpers.state import AsyncTrackStates File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/state.py”, line 8, in from homeassistant.components.media_player import ( File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/media_player/init.py”, line 24, in from homeassistant.components.http import HomeAssistantView, KEY_AUTHENTICATED File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/init.py”, line 34, in from .static import FILE_SENDER, CACHING_FILE_SENDER, staticresource_middleware File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/static.py”, line 6, in from aiohttp.file_sender import FileSender ImportError: No module named ‘aiohttp.file_sender’ 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Unable to find component history 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Component not found. 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.http. Make sure all dependencies are installed Traceback (most recent call last): File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/loader.py”, line 141, in get_component module = importlib.import_module(path) File “/usr/lib/python3.4/importlib/init.py”, line 109, in import_module return _bootstrap._gcd_import(name[level:], package, level) File “”, line 2254, in _gcd_import File “”, line 2237, in _find_and_load File “”, line 2226, in _find_and_load_unlocked File “”, line 1200, in _load_unlocked File “”, line 1129, in _exec File “”, line 1471, in exec_module File “”, line 321, in _call_with_frames_removed File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/init.py”, line 34, in from .static import FILE_SENDER, CACHING_FILE_SENDER, staticresource_middleware File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/static.py”, line 6, in from aiohttp.file_sender import FileSender ImportError: No module named ‘aiohttp.file_sender’ 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Unable to find component http 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Component not found. 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.tts. Make sure all dependencies are installed Traceback (most recent call last): File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/loader.py”, line 141, in get_component module = importlib.import_module(path) File “/usr/lib/python3.4/importlib/init.py”, line 109, in import_module return _bootstrap._gcd_import(name[level:], package, level) File “”, line 2254, in _gcd_import File “”, line 2237, in _find_and_load File “”, line 2226, in _find_and_load_unlocked File “”, line 1200, in _load_unlocked File “”, line 1129, in _exec File “”, line 1471, in exec_module File “”, line 321, in _call_with_frames_removed File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/tts/init.py”, line 24, in from homeassistant.components.http import HomeAssistantView File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/init.py”, line 34, in from .static import FILE_SENDER, CACHING_FILE_SENDER, staticresource_middleware File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/http/static.py”, line 6, in from aiohttp.file_sender import FileSender ImportError: No module named ‘aiohttp.file_sender’ 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.loader] Unable to find component tts 17-03-22 04:06:33 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: Component not found.’
Sorry for the long list
