Hi guys,
I currently have a problem with the device and entity registration in Home Assitant via MQTT(Mosquito Add-ON).
In my example I register 4 devices in Home Assitant:
summary_device = {
"name": f"DKB Zusammenfassung {model}",
"identifiers": f"dkb_summary_{model}",
"manufacturer": "Justin Hahn",
"model": model
activities_device = {
"name": f"DKB Aktivitäten {model}",
"identifiers": f"dkb_activities_{model}",
"model": model
The whole function runs in a loop and {Model} differs in the runs, so there is no problem that the ID is not unique
The curious thing is that only 2 devices are registered in Home Assistant (in my case the loop runs through twice, but only the devices from the first run are registered).
Now comes the strange thing.
If I run the whole programme once, I only have 2 devices and their entities in Home Assitant, which does not change even if I run the programme 10 times. That is logical so far. But if I now change the identifiers of both devices (e.g. I write _1 in the end) then I suddenly have 6 devices in HomeAssitant, which means that suddenly all 4 devices are registered. If I then delete all devices from HomeAssitant again and start the programme with the changed identifiers, there are only 2 devices again, so I have to do the following to register my 4 devices:
- run the programme once (2 devices are registered)
- change the identifiers (4 devices are registered)
- delete the 2 now superfluous devices.
I am not very familiar with MQTT but I think that this behaviour is not normal, or is it intentional?
I have also made a video about this because the whole situation is very confusing and I may not have explained it here so that everyone understands it:
https://youtu.be/7004sN_BKGc
I have also made all my code public here.
In the logs of the MQTT PLugin there is nothing that really helps me (thought there might be an error why only 2 devices are registered).
I’ve also thought about opening an isseu on Github but maybe this behaviour is intentional (even if I couldn’t imagine why it should be).
Thank you in advance for your answers.
2024-06-15 00:51:50: New connection from 172.30.32.1:52403 on port 1883.
2024-06-15 00:51:50: New client connected from 172.30.32.1:52403 as 3OEpiKXoq9nlbFNXHxn6lM (p2, c1, k60, u'homeassistant').
2024-06-15 00:52:11: New connection from 217.87.170.124:64390 on port 8883.
2024-06-15 00:52:11: New client connected from 217.87.170.124:64390 as auto-EBCDBFAD-756A-9ADF-BF4B-9F873354EBE9 (p2, c1, k60, u'mqtt_test').
2024-06-15 00:52:11: Client auto-EBCDBFAD-756A-9ADF-BF4B-9F873354EBE9 disconnected.
2024-06-15 00:52:11: New connection from 217.87.170.124:64393 on port 8883.
2024-06-15 00:52:11: New client connected from 217.87.170.124:64393 as auto-CA234FCE-C08F-3408-7301-5F46163537CB (p2, c1, k60, u'mqtt_test').
2024-06-15 00:52:11: Client auto-CA234FCE-C08F-3408-7301-5F46163537CB disconnected.
2024-06-15 00:52:14: New connection from 172.30.32.1:51637 on port 1883.
2024-06-15 00:52:14: New client connected from 172.30.32.1:51637 as 4m0LtlDdcyrFuTPX40FLeg (p2, c1, k60, u'homeassistant').
2024-06-15 00:52:40: New connection from 217.87.170.124:64421 on port 8883.
2024-06-15 00:52:40: New client connected from 217.87.170.124:64421 as auto-DEE7F711-4BDA-9ADF-2DCB-E6BF18EB7DEB (p2, c1, k60, u'mqtt_test').
2024-06-15 00:52:40: Client auto-DEE7F711-4BDA-9ADF-2DCB-E6BF18EB7DEB disconnected.
2024-06-15 00:52:41: New connection from 217.87.170.124:64425 on port 8883.
2024-06-15 00:52:41: New client connected from 217.87.170.124:64425 as auto-A5FC5FE4-D229-F506-5148-587C78ABA46D (p2, c1, k60, u'mqtt_test').
2024-06-15 00:52:41: Client auto-A5FC5FE4-D229-F506-5148-587C78ABA46D disconnected.
2024-06-15 00:52:46: New connection from 172.30.32.1:54117 on port 1883.
2024-06-15 00:52:46: New client connected from 172.30.32.1:54117 as 0POXj0icSnPkY2RQrZL167 (p2, c1, k60, u'homeassistant').
s6-rc: info: service legacy-services: stopping
[22:53:04] INFO: Service restart after closing
2024-06-15 00:53:04: mosquitto version 2.0.18 terminating
2024-06-15 00:53:04: Saving in-memory database to /data//mosquitto.db.
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[00:53:21] INFO: Certificates found: SSL is available
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[00:53:21] INFO: Starting NGINX for authentication handling...
s6-rc: info: service legacy-services successfully started
[00:53:22] INFO: Starting mosquitto MQTT broker...
2024-06-15 00:53:22: Warning: Mosquitto should not be run as root/administrator.
2024-06-15 00:53:22: mosquitto version 2.0.18 starting
2024-06-15 00:53:22: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-06-15 00:53:22: Loading plugin: /usr/share/mosquitto/go-auth.so
2024-06-15 00:53:22: ├── Username/password checking enabled.
2024-06-15 00:53:22: ├── TLS-PSK checking enabled.
2024-06-15 00:53:22: └── Extended authentication not enabled.
2024-06-15 00:53:22: Opening ipv4 listen socket on port 1883.
2024-06-15 00:53:22: Opening ipv6 listen socket on port 1883.
2024-06-15 00:53:22: Opening websockets listen socket on port 1884.
2024-06-15 00:53:22: Opening ipv4 listen socket on port 8883.
2024-06-15 00:53:22: Opening ipv6 listen socket on port 8883.
2024-06-15 00:53:22: Opening websockets listen socket on port 8884.
2024-06-15 00:53:22: mosquitto version 2.0.18 running
2024-06-15 00:53:22: New connection from ::1:55680 on port 1883.
2024-06-15 00:53:22: Client <unknown> disconnected due to protocol error.
[00:53:23] INFO: Successfully send discovery information to Home Assistant.
[00:53:23] INFO: Successfully send service information to the Supervisor.
2024-06-15 00:53:28: New connection from 217.87.170.124:64443 on port 8883.
2024-06-15 00:53:28: New client connected from 217.87.170.124:64443 as 897aac36 (p2, c1, k15, u'justins_pc_mqtt').
2024-06-15 00:53:29: New connection from 172.30.32.1:52679 on port 1883.
2024-06-15 00:53:29: New client connected from 172.30.32.1:52679 as 4dACVaaX45wJDKcRua21A0 (p2, c1, k60, u'homeassistant').
2024-06-15 00:53:29: Client 4dACVaaX45wJDKcRua21A0 disconnected.
2024-06-15 00:53:29: New connection from 172.30.32.1:46353 on port 1883.
2024-06-15 00:53:29: New client connected from 172.30.32.1:46353 as 06g9o2oSgOJlY8jh5qmO5a (p2, c1, k60, u'homeassistant').
2024-06-15 00:53:37: New connection from 217.87.170.124:58154 on port 8883.
2024-06-15 00:53:37: New client connected from 217.87.170.124:58154 as DVES_AAE670 (p2, c1, k30, u'stromzähler_mqtt').
2024-06-15 00:53:40: New connection from 217.87.170.124:64463 on port 8883.
2024-06-15 00:53:40: New client connected from 217.87.170.124:64463 as auto-1AEA5DC8-82DE-268B-4653-B5AC20C9E129 (p2, c1, k60, u'mqtt_test').
2024-06-15 00:53:40: Client auto-1AEA5DC8-82DE-268B-4653-B5AC20C9E129 disconnected.
2024-06-15 00:53:40: New connection from 217.87.170.124:64467 on port 8883.
2024-06-15 00:53:40: New client connected from 217.87.170.124:64467 as auto-060EEAA0-B8C8-0863-5BD7-9FED304C5E50 (p2, c1, k60, u'mqtt_test').
2024-06-15 00:53:40: Client auto-060EEAA0-B8C8-0863-5BD7-9FED304C5E50 disconnected.
2024-06-15 00:53:46: New connection from 172.30.32.1:45053 on port 1883.
2024-06-15 00:53:46: New client connected from 172.30.32.1:45053 as 20UtPFxgpU8LmXjxAEtzlx (p2, c1, k60, u'homeassistant').
2024-06-15 00:54:02: New connection from 217.87.170.124:64489 on port 8883.
2024-06-15 00:54:02: New client connected from 217.87.170.124:64489 as auto-C1454D53-C009-A681-9827-0EFAF69E9BB8 (p2, c1, k60, u'mqtt_test').
2024-06-15 00:54:02: Client auto-C1454D53-C009-A681-9827-0EFAF69E9BB8 disconnected.
2024-06-15 00:54:02: New connection from 217.87.170.124:64492 on port 8883.
2024-06-15 00:54:02: New client connected from 217.87.170.124:64492 as auto-93CD3615-ACC5-360E-66C1-80870C910B91 (p2, c1, k60, u'mqtt_test').
2024-06-15 00:54:02: Client auto-93CD3615-ACC5-360E-66C1-80870C910B91 disconnected.
2024-06-15 00:54:05: New connection from 172.30.32.1:34849 on port 1883.
2024-06-15 00:54:05: New client connected from 172.30.32.1:34849 as 7ycUhqNk5KAaJNPwEfznMa (p2, c1, k60, u'homeassistant').
2024-06-15 00:54:20: New connection from 217.87.170.124:64513 on port 8883.
2024-06-15 00:54:20: New client connected from 217.87.170.124:64513 as auto-A49AEF5A-1E79-E75E-3801-66915040596D (p2, c1, k60, u'mqtt_test').
2024-06-15 00:54:20: Client auto-A49AEF5A-1E79-E75E-3801-66915040596D disconnected.
2024-06-15 00:54:21: New connection from 217.87.170.124:64516 on port 8883.
2024-06-15 00:54:21: New client connected from 217.87.170.124:64516 as auto-42AE8BDC-A389-9056-A8AC-D0FC227DDDF2 (p2, c1, k60, u'mqtt_test').
2024-06-15 00:54:21: Client auto-42AE8BDC-A389-9056-A8AC-D0FC227DDDF2 disconnected.
2024-06-15 00:54:26: New connection from 172.30.32.1:44471 on port 1883.
2024-06-15 00:54:26: New client connected from 172.30.32.1:44471 as 7I5Ec3LbYSdPE7PvkCYLsp (p2, c1, k60, u'homeassistant').
2024-06-15 00:55:21: Client 06g9o2oSgOJlY8jh5qmO5a has exceeded timeout, disconnecting.
2024-06-15 00:55:39: Client 20UtPFxgpU8LmXjxAEtzlx has exceeded timeout, disconnecting.
2024-06-15 00:55:57: Client 7ycUhqNk5KAaJNPwEfznMa has exceeded timeout, disconnecting.
