Home Assistant 2023.9.2
Supervisor 2023.09.2
Operating System 10.5
Interface utilisateur : 20230911.0 - latest
I’ve configured an external access with Nginx and letsencrypt. I can access to my HA system (using a 4G connection) with my dns in https using Firefox on my phone (Android 11) but i can’t via chrome, Vivaldi and via the HA Companion. I have this error
chromium: [ERROR:ssl_client_socket_impl.cc(975)] handshake failed; returned -1
If im logged to my Wifi, the HA Companion client can login else if im using a 4G connection i cant login… Once loaded it says “Unable to connect to HA”
If someone could help me that would be great
Thank you !
the pop-up message itself should give you the reason for the error like invalid certificate date or untrusted certificate authority etc… does it not show you that?
oh wow thats a frontend error message, app wont be able to help with that. Most likely a proxy issue. We do have some tips but as HA does not support it directly we can’t help much.
Just to explain, i just want to provide an external access to HA so it can communicate the Google API. That’s just why i need an external access. My Google Home devices can communicate and integrate HA entities and so on. The only problem that i have is when i want to use Companion outside my house… If you have another solution instead of using nginx im ready to hear
