I updated my module to support multiple HOME CONNECT device types without having to add a module for each device. You can keep your existing refresh token:
Oven (steamer & normal oven), dishwasher, washer and dryer is working fine.
Hey all, can anyone whoās using a homeconnect dishwasher tell me if it can report whether the door is open or not?
I want to set up an automation to tell whether the dishes are clean or dirty, and this is the part Iām missing with my smart plug based setupā¦
Or can the washer just tell if the dishes are clean somehow?
door state is working, even if the dishwasher isnāt onā¦
No, the washer doesnāt know if the dishes are clean⦠you could perhaps create some sort of template sensor that defines the dishes as clean after a program did run and the door wasnāt openedā¦
but as soon as you open the door and donāt remove the dirty dishes you cannot tell if it is cleanā¦
Yes, that was exactly what I was thinking in terms of automation. Okay so itās worth jumping through the hoops to set up SSL for this then, thanks for the confirmation!
You donāt even need SSL⦠It is working without using SSL or exposing your HA to the web.
Oh my god, thatās great! I had been planning to use the below, didnāt know about this one. Thanks so much!
Custom component for Home Assistant to connect appliances supporting the Home Connect standard (WIP) - DavidMStraub/homeassistant-homeconnect
I tried this but get:
"error": "unauthorized_client",
"error_description": "client not authorized for this oauth flow (grant_type)"
Can you please make a detailed step by step walktrough?
Please see the installation part in the Readme-File. I used this as well and worked. I used the linux console for the commands for the OAuth2 procedure.
Installation:
<config_dir>/custom_components/home_connect/
.Device flow
for OAuth flow.export CLIENT_ID="YOUR_CLIENT_ID"
curl -X POST -H "Content-Type: application/x-www-form-urlencoded" -d "client_id=${CLIENT_ID}" https://api.home-connect.com/security/oauth/device_authorization | tee tmp.json
verification_uri
in a browser, type in user_code
. Log in using your (end user, not developer) Home Connect account and approve.export DEVICE_CODE=$(jq -r .device_code tmp.json)
curl -X POST -H "Content-Type: application/x-www-form-urlencoded" -d "grant_type=urn:ietf:params:oauth:grant-type:device_code&device_code=${DEVICE_CODE}&client_id=${CLIENT_ID}" https://api.home-connect.com/security/oauth/token | tee access_token.json
jq .refresh_token access_token.json
Put the following in your home assistant config:
- platform: home_connect
refresh_token: "YOUR_REFRESH_TOKEN"
HI,
I have been looking at this integration for a week now or something.
It worked fine when I installed. All actions, door open/closed, programms, all detected correctly. And it has been running fine untill yesterday. Now I dont get info of the device anymore. It is there in HA, but the info is not updated I think. dont know why. Nothin in the log file I think.
Is there anything I can do to help you with the right logs ? to try to understand it?
regards,
Dear nontijt
Thanks for using the integration. Do the HC devices correctly appear inside the HOME CONNECT App on your smartphone?
Try to add home_connect to your logger by adding the following to your configuration.yaml, then you should get additional infos:
logger:
default: info
logs:
custom_components.home_connect: debug
This, perhaps? https://github.com/DavidMStraub/homeconnect/issues/3
I expanded the installation and usage part for my integration:
Actually I didnāt notice the problem that the sensors stop working? Which integration did you use?
I do not want to create a mess with the integration from DavidMStraub, so maybe Iāll just create another topic to avoid further confusing⦠Sorry for that.
Now a seperate topic: HOME CONNECT INTEGRATION (working even without SSL & not exposing HA to web)
@cotwild can you please start a new thread? It is really confusing to have Q & A on two different integrations in the same thread.
Sorry, just noticed you just announced that!
Sorry, I might be causing more uncertainty than needed.
The integration I used is the one in HACS.
https://github.com/DavidMStraub/homeassistant-homeconnect
In the bottom of this page, there is a link to this thread, So I assumed this is the correct place. But I am unsure now, reading there are two versions.
Is this the right thread? Sorry if I misposted.
If this is correct, I will add the debug line written above.
Regards,
Naive question: is there any timing on when the pull request for this integration into HA will be merged?
I wish there were. Iām frustrated about it too, but the problem is that I still have no clue how to fix this bug: https://github.com/DavidMStraub/homeconnect/issues/3. It doesnāt make sense to merge the PR until this is fixed. Any help is highly welcome.
Hello
Great work, i have the option to test the following things
Oven HM876GDB6S
Dishwasher SN678X66TE
Extractor hood LR29CQS25
Cook top EX877KYX5E
Coffemaker CT836LEB6
One thing i can see i already are missing is the option to control the light of the hood, i hope you will have a look at sometime. Edit there is already a issue on it https://github.com/DavidMStraub/homeassistant-homeconnect/issues/57
Hi guys, I canāt get this to work using a nabu casa url. Has that been done before?
is there an update on this topic already?
I am also looking forward to this feature
Hi, I have everything in place. but upon adding the integration (the above one is the list, there are 2?) I am forwarded to an authorization site⦠but I cannot get passed thatā¦
I even am locked out after a whileā¦
I am 100% sure i have added the correct credentials and in the registered application on the developer portal as wellā¦
After timeout:
what can be wrong?
